10-17-2017, 05:48 PM | #1 |
Drives: 2013 SS 1LE Join Date: Jan 2011
What gives?
Went in to the dealership this morning for an oil change. I remind them that the LS3 requires 8 quarts. Upon completion, I ask if they put 8 quarts in, work order states 6. I have them check the oil before I leave the dealership, oil readings are fine. I drive it a couple of miles, no dummy lights or anything on, i stop to check it and it's fine. I check the oil again when I get home, still fine. Question is, I thought these LS3s required 8 quarts? Did the dealership not drain all of the 8 quarts out? I'll check it again before I fire it up again just to be on the safe side
Drives a 13 SS
99 SS, Current Project car RIP 99 Z28 Last edited by hector95z; 10-17-2017 at 09:51 PM. |
10-17-2017, 06:14 PM | #2 | |
Drives: 2013 Camaro 2SS/RS Join Date: Apr 2014
Another option is to find an independent shop to do your maintenance. My shop allows me to buy my own oil and filter all I pay is $20 for labor. |
10-17-2017, 06:18 PM | #3 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I change my own, and it takes 8 quarts
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
10-17-2017, 06:20 PM | #4 |
Drives: 2013 Camaro 2SS Join Date: Aug 2013
My invoices always state six. However, they do put in eight. They just do not charge me for the last two quarts.
10-17-2017, 06:25 PM | #5 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
This happened to me once before. The service advisor will note 6 quarts but the tech will put 8 quarts.
10-17-2017, 07:16 PM | #6 |
Drives: 2017 1SS auto vert Nightfall Gray Join Date: Jan 2017
I’ve seen this too. The service software may only go up to 6. I always check the level before I leave the shop.
10-17-2017, 08:37 PM | #7 |
Drives: 2013 Black SS/RS Join Date: May 2017
Dayum, I guess I need to start checking my invoices a little closer. And my dipstick.
Do you mean to tell me the dealerships software is read between the lines? Outdated? Some know,some don't. Just guess And they are working on a car with 19 computers on it? I'm dreading the day I get a bad software buggy problem on this car. Who is going to work on these cars in 15 or 20 years? Hopefully these highly intelligent tech savvy good people on this forum will help us. |
10-17-2017, 09:04 PM | #8 | |
Drives: 2013 ZL1 Join Date: Nov 2015
10-17-2017, 09:06 PM | #9 |
'Maro
Drives: 2015 SS 6.2L Auto 2SS Join Date: Sep 2016
Finger? Hehehe
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
10-17-2017, 09:50 PM | #10 |
I don't mind doing my own oil changes. I did one on my 10 SS before I traded it in on the 13. Only reason I took it in was because I received two complimentary oil changes wit the purchase of the car. I'm not sure these so called free oil changes are worth it with some of the stories that I've heard from people
Drives a 13 SS
99 SS, Current Project car RIP 99 Z28 |
10-17-2017, 10:16 PM | #11 |
Drives: 2013 2SS/RS Join Date: Nov 2015
10-18-2017, 04:53 AM | #12 |
Just an average Dude
Drives: 2015 1LT Grey w/Orange Rally Stripe Join Date: Mar 2016
The advisors don't know anything about your cars. I learned this many years ago with the Dodge dealers who didn't know to empty the water separator on my diesel at oil changes and wanted to start an argument about it.
So far I like my car the way it came from the factory.
10-19-2017, 10:18 PM | #13 |
Russ
Dang it, my dealer charges me for all 8qts of Mobile one. I better mention that all of the other dealers give 2qts for free!
10-20-2017, 07:14 AM | #14 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
I just got my 2nd free oil change at 1500 miles. They put in 10 quarts. Luckily my dealer is competent and mod friendly. They also let me supply my own oil and filter and will do the change for $15.
