Old 10-18-2017, 06:35 PM   #1
Teddydog
Teddydog's Avatar
Drives: 21 LT1 RS M6 in SSM
Oil catch can install: PCV valve tubing
I want to install an oil catch can, but I am reluctant to cut apart the factory rigid line between the valve and the insert into the plenum. It is covered by a plastic "loom" material and appears to be seamless (or permanently connected) from one end to the other. The valve end has a lock clip for the valve tip and the other end appears to become the insert for the plenum.
Can I get a replacement one to chop up and use for the catch can install? I don't see it at Rock Auto. Can someone provide a part or assembly number so I can try to find/order one?
Thanks!
Rob
Teddydog is offline   Reply With Quote
Old 10-18-2017, 08:05 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Think this is what you need (part no. 12616915): https://www.wholesalegmpartsonline.c.../12616915.html
I also bought a second tube to install my catch can since I'm still under warranty; here it is for the LFX engine (part no. 12638437): https://www.wholesalegmpartsonline.c.../12638437.html
KillboyPowerhead is offline   Reply With Quote
Old 10-19-2017, 12:37 PM   #3
Teddydog
Teddydog's Avatar
Great info! That looks like the creature. Thank you very much!
Rob
