Old 10-22-2017, 08:34 AM   #1
Lacpac
Lacpac's Avatar
Drives: 2012 Crystal Red Tintcoat RS
P0442 Check Engine Code
Not sure if you guys are aware, but there is a Technical Service Bulletin on the 2012 LFX for this problem. I erased my codes not realizing the dealer needs to see the code in your history so they can diagnose it and fix the Evap Solenoid problem.
Lacpac is offline   Reply With Quote
Old 10-22-2017, 03:06 PM   #2
Silent...
Silent...'s Avatar
Drives: 2012 2LT RS White Born: 11/10/11
Plenty of discussion on it already. Search. Replaced the fuel cap on mine and took care of it in my case.
*Grey Hockey Stripes; Heritage Grill; GM GFX - Unpainted Argent Gray; GM Dovetail Spoiler; Rivercity Creations custom painted rear bowtie, RS & Taillight Bezels; MRR M017 Graphite Wheels; Nitto NT555 G2; ACS 4Teen Heat Extractor
*RX Catch Can;CAI; MF Exhaust; VMAX CNC Spiral Ported TB; Overkill Stage 1 Supercharger System; Hotchkis Comp Sway Bar Set w/ End Links, Cadillac CTSV 4 Piston Brembos on all corners with SS Black Hat Rotors
Youtube Channel - HPDE Driving Videos https://www.youtube.com/channel/UCpO...8aw6hgX3O1Uh7A
Silent... is offline   Reply With Quote
Old 11-11-2017, 06:32 AM   #3
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
Some codes are "permanent" and not erased by many of the code readers. I have two readers and one shows it and the other doesn't after clearing.
blackswan is offline   Reply With Quote
Old 11-18-2017, 07:43 PM   #4
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
Here was my cause of P0442
Old 11-28-2017, 02:31 PM   #5
Lacpac
Lacpac's Avatar
Photos cause of 0442
So what are these photos showing. Vac leak?
Use zip ties to fix? The dealer said next time the code shows, don't erase it and they will diagnose then replace the part. I already replaced the gas cap.
Of course I've been code free since the last one in October.
Old 07-29-2018, 06:45 AM   #6
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
The top photo with yellow circle is showing that the hose came off. I took that picture when I removed the engine cover and there it was just sitting like that.
Old 08-02-2018, 12:37 PM   #7
Lacpac
Lacpac's Avatar
In will have to check that. I haven't had the code appear since the one time last year. Some say it happens when you get low in the gas tank. Already replaced gas cap. That might have been the trick. I did do the PCV drill mod but that was long before the code showed up. I'll check those hoses again. Thanks.
Old 08-02-2018, 01:29 PM   #8
Marklar
Drives: 2012 Camaro LS V6
Funny that this thread come up now after almost a year. I just had this code happen on my car AND I replaced my gas cap AND the code persists. My local parts store said it's common and doesn't really affect anything but if the new gas cap doesn't take care of it I will probably have to replace the evap solenoid (pump?) and it's like a $50 part that takes 10 mins to replace. He said I shouldn't worry about it, but I still want the CEL to go away.
Marklar is offline   Reply With Quote
Old 09-15-2018, 09:54 AM   #9
SlickP
Drives: 2016 2SS Convertible
I am having this same problem I replaced the gas cap and the check engine light is still on. I check for lose hoses and did not see anything. I was told to replace the EVAP solenoid. Should I take this to Chevy and pay them to fix this or just replace the part?
SlickP is offline   Reply With Quote
Old 03-24-2019, 09:55 AM   #10
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
Just replace it, will cost you at least that much to have them tell you to replace it anyway and then they will charge you a LOT more. Besides, they go bad, not the worst thing to have a new one installed and go from there. I'm planning on doing this and gas cap probably every 30k or so, sadly.
