![]() Drives: 2015 camaro ls v6 6spd manual Join Date: Oct 2017
2015 camaro ls v6 performance upgrades ?
I am the proud owner of a 2015 Camaro ls v6 6spd manual,my first camaro. not the ss i know but i love it,Red Hot Red. i want to upgrade the performance some till i can go forced induction via supercharger or turbo .I want to gain some rwhp,and tq . ill start with CAI ,and exhaust.i want a nice exhaust that has that American muscle car rumble . pls any suggestions ,comments ,or videos about performance parts / upgrades will be greatly appreciated .
![]() Drives: 2LS CAMARO Join Date: Jul 2017
I have a 2015 2ls. I have k&n filter in stock/modified air box. Airaid elbo. I installed stock ss exhaust bigger pipe better air flow. The biggest change was to install a SS rear axle assembly. Since mine had the 2.92 gear I installed the manual 3.45 assembly. very noticeable difference in performance. before swap 1/8 mile was 9.68 in the summer heat. after swap 1/8 mile 9.09 in the heat expect to see 8.8's this winter.
old school chevy rodder
Though your loving your v-6 the sound you may want might not be so attainable, so you have to go with what god gave you. The deal also is; it is what it is, other than some mild mods for a CAI and some exhaust the mod money is best spent on Vinyl or other things for you to personalize the car, as always on here usually the best mod for a v-6 is to upgrade to a SS....... You want to chase power, you could save up and go used zl1 with low prices now for fifth gens and maybe be into it about what your LS with turbos and or supercharging would be, If you want a kick in the pants a set of gears will make you smile......Listen to some exhaust clips on the net....and here form old posts, good luck you can use the search threads on the top menu bar with key words...... or go to the appropriate section.
#4 | |
![]() ![]() Drives: 2015 Chevy Camaro 2LS Join Date: May 2017
![]() Drives: 2015 Camaro 1SS L99 Join Date: Apr 2016
I have the SS with the Stainless works exhaust system so a little different, but I 100% stand by the company. Since you have a mod budget, I vote for catback. Look at this link and look up some videos. Sounds mean as hell
http://stainlessworks.net/chevy-camaro-v6-2010-exhaust |
#6 | |
![]() Drives: 2014 Camaro 2LS Join Date: Nov 2015
2014 Camaro BLK 2LS, MRT 2 exhaust,CAI,Anzo projector headlights,Morimoto HID,Aftermarket fog lights,RS tail lights, Strut tower brace.
#7 |
I also want to quickly chime in on the "upgrade to a higher trim if you want more power" argument as I recently just went through this debate. Own the car that makes the most sense financially to finance. Then spend your extra car budget on mods to make you love that car more.
I want to mod my 2015 SS to add 100+ HP. My mod budget when this is all said in done will probably be over $5000. At that point it looks like It makes sense to upgrade to a 2013 used ZL1 instead. However, I'm financing my current car at 0%. The best I could do for the used ZL1 is 5 years at what, 3.9%? Doesn't always make sense to upgrade cars. Maybe this guy is in the same boat where he is paying for the most car he can afford on a monthly budget, and then sinking some extra money in when he can. I know that's what I decided to do. GL OP, hope you like the Stainless works stuff I linked, they are top notch |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Corvette Stingray Z51 Join Date: Aug 2011
You won't get that "american muscle" rumble from the 6. There are some setups that can give a nod to that sound at idle but with any throttle you're going get the V6 sound. The popular options are MRT2, SLP Loudmouth, Borla, Corsa. All of these are louder than they sound in clips so I'd strongly recommend trying to get some in-person samples. I ran an SLP Power-Flo on my 2010 2LT which isn't as obnoxious but was still enough to vibrate the wall in the kitchen next to the garage until it idled down and had some pretty good drone at highway speeds. It's all going to be very subjective. Do your homework.
CAI and such are minor gains and typically the returns are up near redline anyway. Looks neat under the hood, sounds good, returns with exhaust are minimal. Tuning, probably another solid net return. Go with Will Overkill for tuning. E85 options and such will also bring decent performance increases. Wait until you have most of your performance mods in place before dropping on a tune. http://www.getoverkilled.ca/products.html For boost, you'll definitely see gains but they won't be on par with V8 torque output without some major modifications. I did run an IPF kit on my 2010 V6 for a bit and it was fun but it's definitely not equal. I'd do it again though if the wife would let me slap one on the '14. She still says no. A side note, the Overkill supercharger solution is a much better solution than I had access to so the returns will be much improved if you want to invest the money (5-6k range). One upgrade I'd definitely suggest is rear gearing. With the M6 you've got, you're running 3.27's. Upgrading to the 3.91's will really bring that thing into it's own and numerically higher gearing compensates for lower torque output. This will probably be the upgrade with the greatest ROI outside of some form of power adder.
![]() 2020 Corvette 2LT Z51 2017 ZL1 A10: (SOLD) || 2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD) Last edited by gpskinzhut; 10-24-2017 at 02:56 PM. |
#9 |
Drives: Camaro V6 Join Date: Oct 2016
You're not going to get that deep "muscle car" rumble with a V6. The V6 has its own sound, sort of like a low end Ferrari. That's what I like about it. It's different than the typical V8 and has its own exotic-like sound and feel to it.
If Will @ Overkill ever gets around to it, then (Mace) cams would be a good option if you wanted to remain N/A. Cams, tune, exhaust, CAI and gears would have it running with the V8's. And, it would cost less than upgrading to a V8 model. |
#10 |
Just an average Dude
Drives: 2015 1LT Grey w/Orange Rally Stripe Join Date: Mar 2016
Typical, It took only 2 posts to get to the "SS" debate with you people. Some people like to work with what they have. Get it through your thick heads.
So far I like my car the way it came from the factory.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Corvette Grand Sport M7 Join Date: May 2012
This! You'll never get a V6 to sound like a V8. Look around, watch some YouTube clips and see which exhaust sounds the best to you. Good luck!
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE "Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!". |
#12 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
#13 |
you think it is biased here? try any large Camaro group on FB. seems that Chevy sold 4 times the number of 8's vs 6 ! lol
#14 |
Indeed, go straight to a 6th gen SS
![]() 2020 Corvette 2LT Z51 2017 ZL1 A10: (SOLD) || 2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD) |
| Tags |
| 2015, camaro, ls v6 |
