Old 10-25-2017, 03:09 PM   #1
2Fast4Mu
Nothing is True
2Fast4Mu's Avatar
Drives: Black 2014 2SS/RS
Mild 2 Wild causing radio problems?
I have a 2014 2SS. Shortly after buying it in 2014, I also picked up the Mild 2 Wild and installed it.
Since having the car, I've been having intermittent problems with the audio disappearing from the driver side speaker. At first I thought it was a loose wire, but I realized it was some kind of power problem. As I increase the volume of the radio, the audio returns.....as I decrease the overall volume (to average listening levels) the audio in the driver speaker comes and goes.
Chevy has looked and looked and can't find the problem. It's not the speaker. It's not the radio they say....
Today I remembered the Mild 2 Wild that I installed so long ago.
Has anyone had problems with Mild 2 Wild negatively affecting the radio, possibly causing the speaker to sound like it has a loose connection?
I'm really scratching my head here....any advice would be appreciated thanks!!!
...Nothing is True, Everything is Permissible...
2Fast4Mu is offline   Reply With Quote
Old 10-25-2017, 03:12 PM   #2
Scotty D
Drives: 2014 1le 1SS CRMT
Where’d you grab the power for it ??
Scotty D is offline   Reply With Quote
Old 10-25-2017, 03:46 PM   #3
2Fast4Mu
Nothing is True
2Fast4Mu's Avatar
It's been so long since I installed it, that I don't remember -- I just remembered that I followed the instructions in the kit.
Old 10-25-2017, 06:23 PM   #4
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
I can't imagine it would be doing that unless you took lower off of the radio or amp's fuse and also grounded properly
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 10-25-2017, 08:26 PM   #5
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
When I have my NPP open it interuppts my bluetooth connection ...but only when I have my cutouts open too
camguynj is offline   Reply With Quote
Old 10-26-2017, 12:53 PM   #6
2thousand2
Drives: 1997 Camaro SS
Disconnect the M2M and re-test? Sounds like your bluetooth/phone speaker function is making the sound go in/out but I am not sure what would cause that.
2thousand2 is offline   Reply With Quote
mild 2 wild, mild to wild, mild2wild, problem, radio
