Old 10-25-2017, 04:44 PM   #1
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
Resistor to turn off airbag light from installing Racing seats
I installed Braum Racing seats a month ago and I hate the stupid airbag light and the notification that pops up every time I start my car. The shop I usually go to to get parts installed said they can install a resistor, but it would be easier and cheaper if someone had a write out of what to do and they would follow that. Any of you guys have a fix for this?
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 10-25-2017, 05:51 PM   #2
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
I'm interested as well.
Not to change the subject which style Braums did you get? Any pictures? Did you brace the seat back to a harness bar or roll bar?
Thanks
Craig
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 10-29-2017, 02:27 AM   #3
krisprz2010camaross
I got the Braum Elite series X seats. The brackets from Planted which is the company Braum gets their brackets from were a pain in the ass! The holes weren’t even aligned and the shop I got the seats from gas to reweld and drill new holes to make it align. Braum says that’s super rare for that to happen and they apologized. I waited about 5 months for the black with white stitching to get back in stock and they are very nice. I’ll post pics later. I haven’t gotten a harness bar/roll bar yet
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 10-29-2017, 05:36 AM   #4
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
Haven't tried this yet but http://www.camaro5.com/forums/showthread.php?t=434170
What else can I do to my Camaro?
ticowarbird is offline   Reply With Quote
Old 10-29-2017, 11:32 AM   #5
krisprz2010camaross
Originally Posted by ticowarbird View Post
Thanks. That thread has a lot of good information. The passenger side looks like to be more work than the driver side. Someone in that thread said they were going to post a DIY but never did so I commented to maybe bring that thread back. Want to get rid of the annoying airbag notification when I turn my car on lol
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 10-29-2017, 11:46 AM   #6
ticowarbird
BOHIC
I hear ya. I have some corbeaus and I want to remove that warning too.
Old 11-07-2017, 11:05 PM   #7
krisprz2010camaross
Bump
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 11-08-2017, 11:16 AM   #8
jc615
jc615's Avatar
Drives: Camaro and Sierra
This is what has been holding me back from changing seats. Hope you find a solution
jc615 is offline   Reply With Quote
Old 11-08-2017, 03:02 PM   #9
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
From my understanding the resistor added will work. It seems this topic is like taboo and you have to pull teeth to get a straight answer on this. I've been holding off on a change on my car as well. I have full power Recaros's and they are heavy as hell. I plan to preserve the Recaro's by removing them and putting them away. I'm gonna add non powered Recaro look alike in my car but I think to avoid the air bag crap I'll just add the seat air bags in the the aftermarket seats. I'll probably do custom upholstery to the aftermarket ones also.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 11-08-2017, 03:12 PM   #10
krisprz2010camaross
That’s exactly what I’m thinking. The shop I have most of my work said to get a write up of the resistor and such so it would be cheaper, but no one seems to have a write up of how to do it. So, i’ll probably just have to spend more money and have them try different resistors and such until the light is gone and no other problems. Didn’t think it would be so hard to find someone who had put a resistor on get rid of the airbag light when other cars are simpler lol
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 11-09-2017, 01:22 PM   #11
y2kgt46
Drives: 2014 Camaro SS
I looked into aftermarket seats when I had my mustang. Corbeau has a video where they installed their seats on a newer mustang with airbags and weight sensors. Might point you in the right direction. Creating a resistor doesn’t seem to bad from what I remember
y2kgt46 is offline   Reply With Quote
Old 11-21-2017, 09:28 AM   #12
fzss
fzss's Avatar
Drives: 2013 SS Camaro
Bump.
fzss is offline   Reply With Quote
Old 11-21-2017, 06:44 PM   #13
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
I installed cipher seats, after driving a few times its really not that bad, clear the signal on the stalk other than that the only thing is the green light on the dash,
here is a pic of the seats, which are really comfortable
bmbbl be is offline   Reply With Quote
Old 11-21-2017, 06:57 PM   #14
fzss
fzss's Avatar
Is the general consensus that the airbag warning means the entire airbag system is DISABLED?
Has anyone successfully installed parts from their OE seats to trick the system into thinking the side airbags are connected and/or a passenger is present?
Doing a lot of searching but not finding consistent results. Not sure if I feel comfortable going from all the airbags functioning to none, but these cloth seats throw me around everywhere in competition settings.
