10-27-2017, 05:55 PM | #1 |
Trunnion failure
Just finished diagnosing the noise from the car today. #7 intake rocker trunnion bearing failure. Yes, it was the Comp trunnion upgrade kit with about 25k on it. What reliable options are out there? The Smith Brothers bushing kit on the BTR website look pretty good to me. I am NOT going back with more bearings. Just a bomb waiting to go off in my opinion.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
10-27-2017, 06:07 PM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
P/N : SUM-141560
Summit racing trunion upgrade...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
10-27-2017, 09:12 PM | #3 |
I went with the C.H.E trunnion bushing kit. It was a little more expensive ~$200 but I don’t recall seeing the Smith Brothers kit until recently. Looks good though.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
10-27-2017, 10:25 PM | #4 |
Drives: 2012 SS/RS MN6 Join Date: Mar 2016
No issue with my brass bushing kit from summit.
10-28-2017, 09:22 AM | #5 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
X2 on the CHE kit $199 from Texas Speed...
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
10-30-2017, 10:15 AM | #6 |
Drives: 2014 Ford SVT Raptor SuperCrew Join Date: Jun 2011
CHE kit.
Phoenix (sold)
2014 Ford SVT Raptor SuperCrew How to hug your camaro Buy the car that you would most like to get beat in. The other guy will always be faster. |
10-30-2017, 10:59 AM | #7 | |
'It's an experiment'
http://www.camaro5.com/forums/showpo...postcount=1457 Easy install... -Don
747 RWHP 794 RWTQ
10-30-2017, 11:39 AM | #8 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Powell Machine on ebay when they have them...16K miles so far..good luck!
10-30-2017, 12:14 PM | #9 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
10-30-2017, 12:36 PM | #10 |
We've been using the Straub trunnion kit for the last two years with great results.
Brandon 801-545-4215 Last edited by JDP Sales; 10-30-2017 at 07:02 PM. |
10-30-2017, 07:00 PM | #11 |
Finished the valve train tear down today and found 3 more bearings with slop in them. Found a new set of rockers with the bushing kit already installed from Steve Morris Engines. Nothing against the BTR trunnion kit, but as I stated, I will not go back with a bearing. Now, my rockers have 25k on them and that may be the service life limit. My builder has stated that they have see very few failures from the Comp trunnion kit. That may be true; and I have no reason to doubt them; but I feel I could have lost my engine, and I should do everything possible to avoid more problems.
08-14-2020, 09:50 AM | #12 |
Dom251
So I have a 2010 Camaro with a trunnion bearing failure... how much roughly would I be looking to dish out of my pockets for that repair??
08-14-2020, 09:51 AM | #13 |
Dom251
Trunnion bearing Failure!
08-14-2020, 10:13 AM | #14 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
$200 for the CHE trunnion kit. if you are paying someone to do it, probably about 3 hours in labor for installing the trunnion kit. If the rockers are chewed and metal shaving in your oil and through the bearings you are possibly looking at an engine rebuild. Might want to drop the pan to clean out the roller bearings, or try a strong magnet on the pan.
