Old 10-27-2017, 10:00 PM   #1
Buddy2
Buddy2's Avatar
Drives: 2012 camaro convertible 45th Ed.
Angry Oil Leaks
My 2012 SS has an oil leak for the second time already. Anybody else had these problems? My car has 12300 miles on the clock. What will it be like @ 50000 I wonder.
Thanks in advance.
CAI Intake, MagnaFlow Exhaust
Buddy2 is offline   Reply With Quote
Old 10-27-2017, 10:03 PM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Where are the leaks?
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 10-27-2017, 10:16 PM   #3
Buddy2
Buddy2's Avatar
The first one was a lower control arm. I haven’t had this one checked out yet.
Old 10-27-2017, 10:21 PM   #4
Clarkstar
Clarkstar's Avatar
Oil leak from the lower control arm?
Old 10-27-2017, 10:25 PM   #5
2ss-booya
2ss-booya's Avatar
Drives: 2015 SS Sedan M6
It's either your strut, brake fluid or cv joint depending if it's rear or front.
2ss-booya is offline   Reply With Quote
Old 10-28-2017, 09:19 AM   #6
christianchevell
old school chevy rodder
christianchevell's Avatar
Control arms have no oil...... You may want to check the oil cooler, the struts, even the engine mounts....
Old 10-28-2017, 04:44 PM   #7
Clarkstar
Clarkstar's Avatar
And the horn fluid resivour...
Old 10-28-2017, 06:52 PM   #8
Buddy2
Buddy2's Avatar
That’s what I thought, but that’s what they said they changed, and the leak went away. It was done by the dealer, under warranty.
Old 10-29-2017, 10:01 AM   #9
christianchevell
follow the oil it always flows down and back, control arm is suspension..... There have been many cases of small leaks from the oil cooler which acts more like a oil heater...
