Old 10-30-2017, 03:38 AM   #1
Qliver
Qliver's Avatar
Drives: 2014 2LT RS
Key stuck in ignition, not getting into "P" gear properly
Hello fellas,
A question regarding the issue with the key getting stuck in the ignition. I did some research and found that there can be several issues causing it. In my case it is definitely caused by the parking gear not kicking in properly. If I wiggle the shifter back and forth I can hear a click, and then the key can be taken out. My car has the automatic gearbox.
Found that there is a part that can be replaced in order to fix the problem:
Part #92213917 - Transmission Gearshift Control (F-Handle)
Has anybody tried repairing it by themselves? Since I live in Europe, Camaro parts are sometimes hard to come by.
Thanks!
Qliver is offline   Reply With Quote
Old 10-31-2017, 09:32 PM   #2
Screwblower
Drives: 14' 2ss convertible
Mine sticks too. I have found through trial and error , restart the car and quickly turn the key to the off position .
Screwblower is offline   Reply With Quote
Old 11-03-2017, 06:59 PM   #3
Qliver
Qliver's Avatar
Drives: 2014 2LT RS
So nobody has tried fixing it themselves?
I don't understand why I should restart the car, isn't it easier just to wiggle the shifter?
Old 11-15-2017, 09:10 AM   #4
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
Mine appears to be related to the steering wheel lock. I need to twist the steering wheel back and forth when the key gets stuck. Used to restart the car but twisting the steering wheel works for me. Design defect from our friends at GM
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 11-15-2017, 10:29 AM   #5
y2kgt46
Drives: 2014 Camaro SS
I just solved this issue. It's the trigger from the shifter to disengage the key. If you listen, when you are in park, squeeze the trigger and you can hear a noise coming from the key. When you shift into park its not making contact. If you put it in park, and hit the trigger once, it should release the key every time. At least it did for me. Hope this helps!
y2kgt46 is offline   Reply With Quote
Old 12-06-2017, 04:12 PM   #6
Qliver
Qliver's Avatar
Drives: 2014 2LT RS
That doesn't really sound like a solution, I would rather do something which prevents this from happening. I don't believe this is normal behavior.
For me this doesn't seem to be related to the trigger, but rather the position of the shifter. If I wiggle it back and forth I can hear a click, and this also releases the key. But the dashboard usually says "P" when this occurs.
Old 12-06-2017, 07:50 PM   #7
fhrex
Drives: 2011 Camaro 2LT/RS
Sounds like an issue with the BTSI solenoid, or an adjustment of the shift cable/linkage, if that's possible.....
fhrex is offline   Reply With Quote
Old 12-06-2017, 09:09 PM   #8
redcoats1976
dealer replaced my shifter under warrantee to fix this issue.
Old 12-06-2017, 09:19 PM   #9
fhrex
Yep, that's where the BTSI solenoid is. Glad you got your issue resolved
Old 12-07-2017, 07:41 PM   #10
redcoats1976
i am wondering if they replaced the whole shifter or just the solenoid.is it a 1-piece deal or could it be replaced on the original shifter?not that it matters,just curious,i used to work on much older cars but this camaro is like looking in the garage and finding a cruise missile.
Old 12-10-2017, 09:01 AM   #11
Qliver
Qliver's Avatar
Drives: 2014 2LT RS
I am also interested in this, because I may have to change it, and pay for it myself
Old 01-27-2018, 06:33 PM   #12
DeanH
DeanH's Avatar
Drives: 2014 2LT/RS
Shifter replacement
I looked up the part number on my service ticket when I had to have mine replaced under warranty and it was the entire shifter assembly. I believe it is under $200.
I'm sure that's not what you wanted to hear, but I hope it helps.
My mods so far: Removed front license plate bracket. Reflective Concepts White bowtie overlay.
DeanH is offline   Reply With Quote
Old 01-27-2018, 09:13 PM   #13
havelegs
havelegs's Avatar
Drives: 24 LT1 M
Wow the same issue happened to me a few times in my car. It seemed to happen more so when it was cold out. I brought it to the dealer and they could not reproduce the issue. I have to press the button on the shifter a few times then hear a click in the steering column, then the key will release. So changing the shifter fixes this issue? And if so, would that require any sort of ecu/tcm flash?? I am tuned, the dealer knows that and even made a comment about it on the service ticket saying "the tune may affect the parking sensor."
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30
havelegs is offline   Reply With Quote
Old 01-27-2018, 11:22 PM   #14
Screwblower
Yes . You have a tuned shifter that holds the key to tight.
I'm thinking of selling my Camaro 2SS convertible just because of shitty stories like this.
gear shift knob, ignition, key stuck
