Old 11-08-2009, 03:53 PM   #1
Carlos Garza
Carlos Garza's Avatar
Drives: 2010 Camaro SS RS
Hurst Shifter install pointers
Tomorrow we are installing the Hurst shifter in my car. The one thing I'm worried about is baking something when we are taking off the console.
Is there anything I need to watch for when we are taking off the console?
Thanks!!!
Carlos Garza is offline   Reply With Quote
Old 11-08-2009, 04:35 PM   #2
2SSjack
2SSjack's Avatar
Drives: 2010 2SS Camaro;
Actually the only thing you have to remove on the inside is the trim around the shifter. Start at the cupholder end and grab it from the boot side and SLOWLY pull it up. Work towards the gauge end, and when all the tabs are clear move it towards the cupholder; there are two tabs that point forward. Just follow the Hurst directions and you will be OK! Oh, it is easier to pry the stock knob off from under it; there is a flat area on the stock stick that you can use a pry bar on. One more thing; there is a heat shield under the car pretty close to where you will stick your arm/s up to remove the assembly. Just remove the two speed nuts and four bolts that hold the underfloor brace and shield, then just slide the shield back. Save the blood donation for the Red Cross!
2SSjack is offline   Reply With Quote
Old 11-08-2009, 07:26 PM   #3
Carlos Garza
thanks man!!! I'll do it tomorrow...
Old 11-08-2009, 08:51 PM   #4
IROCanSS
Drives: 89 IROC 350
I did mine this weekend. Its easy and the previous post are right.
If you dont have a lift, raise the front and back of the car. I put the car up about 1' Makes the job a snap.
Center cluster removal: This was my biggest fear, breaking somehting. Fear not, it comes right off. The hold on the clips is not very srong. Pull easy, do not yank.
The shift knob removal: Sit on the console and put on leg on each side (straddle the center tunnel) and take the boot over the knob (like removing a kids shirt) and it pops right off. No need to pry anything.
I didn't remove the heat shield and i still have all my blood! No wounds here.
Removing the pin clips is a bit tricky. Just make sure you dont drop and lose them! I dropped one but lockily it fell right on my chest.
Removing the 10?mm bolts... remove the shift linkage pin first then yank the linkage out of the shifter and move it side to side depending what bolt you are removing. makes access easier.
Installing the hex screws is a PITA due to access. I put a dab of grease on the allen socket head and put the screw on. the grease held it in place so i could get it up in the hole since its a VERY small screw and a very tight location. Ever play the game operation?
Putting the dust cover back on SUCKS. you have to try to get both hands up there... good luck!
Once you are done under the car, you are home free!
MOST IMPORTANTLY:
Work slow and take you time.
Read the directions, they are perfect.
Enjoy. I have 400+ miles on my car since the install yesterday... WOW
But I ordered this knob today. I think it is way nicer in black and doesn’t have the redundant shift pattern.
It was super easy to install. About 2 hours in the driveway taking our time and trying to figure the best way to get the car up so I could get under it. It was a no-nonsense install.
Old 11-08-2009, 09:02 PM   #5
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Hey, I've seen that picture before!
Old 11-08-2009, 09:30 PM   #6
comm54
SoCal C5 Family Member
comm54's Avatar
Drives: 2SS/RS IBM M6-when she lets me
Installed mine last weekend!!!
Yes to everything jrhaus76 said; including the part about playing Operation
Do watch out for the heat sheild that 2ssjack mentioned...
If you drop anything while working underneath the car, it will probably land on the heat sheild...
It really is pretty easy and I really love ours!!!
comm54 is offline   Reply With Quote
Old 11-08-2009, 09:58 PM   #7
IROCanSS
Drives: 89 IROC 350
What can I say....
Old 11-09-2009, 07:12 PM   #8
TRooper
Resident Stormtrooper
TRooper's Avatar
Drives: Creations n' Chrome Red Mustang GT
If you can wait a day, I will have the official installation video up on our YouTube site. It is 99.99% done I'm just waiting on the production company to finish a minor edit. I'm leaving the office tonight, but I may be able upload it tonight.
TRooper is offline   Reply With Quote
Old 11-09-2009, 07:58 PM   #9
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Thanks T Rooper for the new Hurst Plaque.
Old 11-10-2009, 08:50 AM   #10
Carlos Garza
Great news, this will help alot. I guess I can wait one more day. Please let me know as soon as you have it ready.
Old 11-10-2009, 09:54 AM   #11
Carlos Garza
Did anyone install the Hurst shifter with the OEM camaro stick and the factory knob? The OEM camaro stick that comes with the hurts kit looks a little shorter than the chromed one, so I guess that using the OEM camaro stick should provide even shorter shifting...
Old 11-11-2009, 10:32 AM   #12
TRooper
TRooper's Avatar
And the video is up now!
Old 11-11-2009, 12:38 PM   #13
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
Nice, I need me one of them there emblems…
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 11-12-2009, 12:57 PM   #14
Carlos Garza
Awesome video man, thanks... I can now say that I have no more questions about the install...
this thread should be a stiky
Hurst Shifter Review on 2SS linkwpc Vendor and Seller review / feedback / experiences 22 06-15-2010 09:27 PM
Dealer Install time for a HURST Shifter? 55Designs V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 10-27-2009 05:13 PM
Hurst Shifter Install FYRFTR02 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 91 10-20-2009 11:04 AM
Hurst shifter install in the M6 2SSRS@Gen5diy Camaro DIY & HOW-TO instructions & discussions 52 10-07-2009 08:36 PM
Shop to install Hurst shifter in DFW? BlackCamaroSS USA - Texas 6 09-18-2009 01:56 PM
