Old 11-08-2009, 03:41 PM   #1
ROBBDOGG1986
Tampa Gulf Coast Family
ROBBDOGG1986's Avatar
Drives: 2010 CAMARO SS
Thinkin about going with Zex... Need a lil help
Wanna put the 75-175 system on from Zex, but I heard from some that the LS3 has too high of a compression ratio?! What does that mean exaclty? Is the compression Ratio too high? If I did get it, what's the highest shot I should do? Would it be ok to use every once in awhile
BALLSS2 the Wall! :5thgenvert:
ROBBDOGG1986 is offline   Reply With Quote
Old 11-08-2009, 04:45 PM   #2
freemaSSon
Pat @ ADM PERFORMANCE
freemaSSon's Avatar
Drives: CGM SS/RS M6
OrangeChevyII is running Nitro Dave's plate shot between 150 and 200.
I would say the information you are getting is not accurate. The ZEX systems are as simple and safe as nitrous can be. I have a very very close friend running a ZEX 150 shot on a Trailblazer SS for over 80,000 miles and is one of the top 5 fastest TBSS's in the entire country on the biggest TBSS board.
1.56 - 60'
7.10 @ 96.21
11.20 @ 120.49
That is at about 4700 race weight.A very simple base model with the ZEX control box is what this TBSS is running.
"old age and treachery will always overcome youth and ambition"
author unknown
"There are two types of racers: cheaters...and losers."
Smokey Yunick
freemaSSon is offline   Reply With Quote
Old 11-08-2009, 04:58 PM   #3
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
You can run thsi kit on the stock car....That is what it is meant for. You can use this kit and still have the car last 100k miles...Of course the more you use it, the more risk you run, but I would say that using the 100HP shot would be safe for a long long time.
I have sold a couple of these kits, and the customers have been very happy, and one guy has not installed yet, but I am sure he will also be very happy. He is waiting for a new engine and doing a 300 shot on top of 12psi of boost!
ZZcamaro is offline   Reply With Quote
Old 11-08-2009, 07:43 PM   #4
mark_p
Drives: 2010 2SSRS m6
I run the zex kit with daves spray plate. 150 shot. LS motors love the juice. The clutch however does not I assure you.
mark_p is offline   Reply With Quote
Old 11-08-2009, 07:47 PM   #5
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
i have a zex kit on a blown 4 cyl. i added a window switch as well as the wot box.
this way you can set it to skip 2 shift before enabling. eg only spray in 3rd, 4th 5th, 6th.
dont ever think of adding gogo juice unless you tune, and monitor car.
ps get the zex black, if you hate purple. fitting s are black too, wire loom the braided cables, and it is hard to spot.
hot ss is offline   Reply With Quote
Old 11-08-2009, 07:58 PM   #6
ROBBDOGG1986
One of you are saying I can run it on a stock car......other is saying I need to tune and monitor car b4 spray
Old 11-08-2009, 08:09 PM   #7
hot ss
hot ss's Avatar
you can run it on a stock motor. any more than a 35-50 shot needs a tune, or your buying a new motor. nitrous causes the explosion to happen at an accelerated rate, which is opposite of adv timing. you need to be able to retard your timing with a decent sized shot....or kaboom, eutectic piston failure and zero warranty.
Old 11-08-2009, 08:10 PM   #8
hot ss
hot ss's Avatar
zzcamaro, chime in plz.
Old 11-08-2009, 08:10 PM   #9
futrocpd
P90X
futrocpd's Avatar
Drives: 2000 SLP SS VERT
not a bad idea to tune it, you would get more power out it if you did. i have ran the juice tuned and not. i would be sure to check your afr before you spray it and start small and work your way up on the jets and just make sure your afr stays in the safe zone. granted this was on a non ls car so i am sure its different for these cars.
2000 Camaro SS/SLP
P90X changed my life. Want to know more, PM me for more info on changing your life for the better
futrocpd is offline   Reply With Quote
ZEX 2010 Chevy Camaro V8 (LS3) Nitrous System Released Tran Forced Induction - V8 10 08-16-2010 07:53 PM
V6 Camaro Owners! 2010 V6 Zex Nitrous System now available! Kris@BMCPerformance Forced Induction 3 01-23-2010 02:41 PM
ZEX Installation Instructions tbyrne Forced Induction - V8 0 09-26-2009 02:03 PM
Yellow Camaro SS in Lil Boosie New Music video! 225WhiteSS Camaro Photos | Spyshots | Video | Media Gallery 16 09-14-2009 09:02 PM
New Zex 2010 Camaro V6 Nitrous Kit - intro and free shipping @ PFYC.com Redshift Forced Induction 0 07-16-2009 08:31 AM
