Old 11-02-2017, 02:36 AM   #1
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
My P013E, P014A Fix
Starting getting the engine check light coming on so I checked the P codes . Found P013E and P014A which roughly has to do with fuel mixture, injector rails ect.
Since the P codes were all fuel related I decided to clean and oil my CAI K&N filter first; the filter didn't look that dirty but I did it anyway.
That fixed the engine check light issue and P codes. I figure, start with the easy stuff first. Just a heads up for anyone who may get these codes.
Cheers
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 12-28-2017, 03:46 PM   #2
Missile Man
I spoke too soon, the errors have returned. Thinks I will try the spark plugs next.
2010 Black 2SS L99
Mods:
* CAI Intake
Old 12-28-2017, 05:27 PM   #3
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
Those dtcs are likely a result of your exhaust modifications. A delayed response from rich to lean on both downstream o2 sensors. How long has it been tuned? To me it suggests the ECM is seeing a rich condition post cat for longer than it wants, suggesting the cats are losing efficiency (for stock cats). Your tuner should have shut these codes out.
JerTM is offline   Reply With Quote
Old 01-09-2018, 09:36 PM   #4
Missile Man
I installed Summit Racing wires and NGK plugs and the check engine light went out. The stock plugs were in bad shape, a lot of electrode ware. I'm at 65K miles, if your running a SC I would suggest you replace your plugs if it's been a while.
My tune includes the exhaust mods, have had the exhaust mods for a while and never received these P codes. Looks like the spark plugs were the issue.
2010 Black 2SS L99
Mods:
* CAI Intake
