11-02-2017, 06:34 PM | #1 |
Drives: 15 z28 white Join Date: Apr 2016
Looking to add some HP over the winter.
It seems like every track day I do I'm always having trouble holding off new Z06s. I realize they may be better drivers than me but I also realize I'm about 150 hp less and 500 lbs heavier. So I'm looking for suggestions for adding about 75-100 more hp or so. I'm bone stock now so I was thinking ARH headers, katech cam, msd intake, valve springs and tune. Can someone chime in with specific suggestions as far as parts? Also looking for suggestions for a place to install in the northeast.
11-02-2017, 07:19 PM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Most will tell you the stock intake is sufficient. Spend that money on a ported throttlebody.
Cam, headers... if you can afford it, get the heads ported
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
11-02-2017, 07:35 PM | #3 |
Drives: Z/28 Join Date: Jan 2015
Do the heads at the same time as the cam - may as well address the valve guide issue while you're in there.
11-02-2017, 08:36 PM | #4 |
Drives: 2015 Z/28 #397 2022 ZL1 #1799 Join Date: Jul 2009
Agreed. WCCH does a great job. Stage 2 is what you want to do. What's your budget on this? 100 hp on the dyno in this car will be over 10k if you have someone do it.
11-02-2017, 08:37 PM | #5 |
I read on another post on this forum that that a ported throttle body does not add any hp. It will only improve throttle response.
11-02-2017, 08:39 PM | #6 |
From everything I've read on this forum there is no valve guide issue on these heads. That issue is Z06 head specific? In fact no one can cite a single failure of a valve guide on a Z28.
11-02-2017, 08:52 PM | #7 |
How much does porting costs go? I'm looking to porn my Zl1 snout myself or get someone to do it professionally.
11-02-2017, 11:34 PM | #8 |
Cheap insurance if you're planning on tracking the thing a lot - especially given you'll be losing the factory warranty. I'd rather spend $10k on the front end and not worry about it than pop a motor and spend twice that to be left with a stock engine.
11-03-2017, 07:02 AM | #9 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Of course I will sound bias but, take a look at the Vengenace Racing site. They offer different stg packages to suit just about any budget. It was the main reason I bought my car with the stg 5 already done. Take a listen and watch the video in my sig.
https://www.dropbox.com/s/seyesgaxdf...32909.mp4?dl=0
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
11-03-2017, 08:23 AM | #10 |
YOLO Z/28
Drives: 2014 Z/28 Join Date: May 2016
The valve issue is still there. There's been 3 documented cases I know of with Z/28's. When I did my cam, at the advice Jeremy Formato of FASTERPROMS, I swapped my heads too. Yeah it's a small investment, but it's worth piece of mind.
2014 Red Hot Z/28, CTF car #39/69. HCI, Supercharged, boltons.
2006 SRM GTO, exhaust, VMR V701 wheels (SOLD) 2002 Bright Red Trans Am WS6: HCI, exhaust, tune, Konis, UMI sways, LCAs, Track bar, STB, 2" boxed steel SFCs (SOLD) |
11-03-2017, 08:27 AM | #11 |
Drives: LSx Powered Join Date: Oct 2009
We see you're not very far away from us. Call or shoot us an e-mail to talk about your Z/28 goals. We have many options for not only power, but track durability as well.
HPA |
11-03-2017, 10:26 AM | #12 |
Drives: 2015 Z28 Join Date: Sep 2016
Do some Mast heads
11-03-2017, 11:37 AM | #13 |
@ElHefeZ28
Drives: 2015 White Z28 Join Date: Jun 2017
My mods...
Stage 2 ProCharger D1 Nick Williams 102 TB Precision Metal Craft Custom Intake TFS Heads Custom Grind Comp Cam Fore Fuel System with dual 450's ProMeth Methanol Injection 1000 CC Injectors AFR Long Tube headers and X Pipe Plans are to change the block and upgrade the procharger over the Winter
Follow me @ElHefeZ28 on Twitter, Instagram, Facebook and Youtube
11-03-2017, 11:43 AM | #14 | |
No good for me though. I need NA for the racetrack. If I was looking for street driving I would definitely consider. |
