11-04-2017, 12:45 PM | #1 |
Drives: 10 IOM SS Join Date: Dec 2014
Halo stays on?! help
Has anyone experienced their halo stay dimly lit when the car is off?
First image is when halo is on second car is off.
11-04-2017, 03:42 PM | #2 |
Drives: 2010 SS Camaro Join Date: Oct 2008
Looks like a bad ground or bad relay. Power is back feeding to the light. i had the same problem on my 2010 camaro but i had an aftermarket relay hooked up to my lights so my day time running lights would be on when my head lights were on. I took the aftermarket part off and it fixed this problem. Hope this helps a little
11-05-2017, 01:19 AM | #3 | |
11-05-2017, 05:36 AM | #4 |
My guess is its the DRL Kit. Mine went bad and did the exact same thing. Disconnect this and check the light. Pretty sure this will take care of your issue. Good luck
