Old 11-05-2017, 07:46 PM   #1
Stud45thSS
Stud45thSS's Avatar
Drives: 2012 Camaro 2ss 45th anniversary
Wire tuck ideas ??
Is there a place to reground the harness that goes on the header side of the head? I'd perfer to run that harness in-between the fuel rail and valve cover
2012 2SS 45TH LS3 M6
MODS: Speed Engineering Long Tubes, RotoFab CAI, Holley Valve Tall Valve Covers.
Stock Dyno: 380hp 386TQ
Headers and CAI: 425HP 434TQ
Stud45thSS is offline   Reply With Quote
Old 11-05-2017, 10:27 PM   #2
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
The back of the driver head has a ground bolt. I'm not sure what harness you're referring to, but that may work for you.
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 11-06-2017, 08:32 AM   #3
Stud45thSS
Stud45thSS's Avatar
This harness. I don't think it would reach the back of the head
Old 11-06-2017, 06:31 PM   #4
christianchevell
old school chevy rodder
christianchevell's Avatar
look for the sticky in the engine section and see if it gives you ideas called; cleaning up the clutter from the engine bay by the Moreno bros....... or something close to that
Old 11-06-2017, 07:30 PM   #5
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
If you need ideas on a tuck, Caitlyn Jenner is always a good option!
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 11-06-2017, 07:34 PM   #6
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Lol!!!
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 11-06-2017, 07:37 PM   #7
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 11-06-2017, 07:54 PM   #8
BLU DUCE
BLU DUCE's Avatar
I dam near bit my tounge.
Old 11-07-2017, 04:04 PM   #9
Stud45thSS
Stud45thSS's Avatar
Geeze that zinger, I'd rather tuck my wires than have them wailing about
