Old 11-08-2009, 11:08 PM   #1
RickyTheStorm
Drives: '10 Camaro 2SS,04 Colorado,06 ZX6R
Several issues - just waiting for more
Okay - so I have 6500 miles on my 2SS/RS (A6) - which by the way I am loving the car! So what is wrong with it - well, a couple things - some are actual issues that need fixed, some I am not sure if they are issues:
1. Tapping noise from passenger front at slow speeds - goes with speed of driving, doesn't matter if in neutral or drive. Reverse does the same, but just at speeds under 30mph. I wish I knew a certain fix to tell the dealer as it seems several people have had this issue but have had several "fixes". It really sounds like it is coming from the passenger front tire, but no rocks, etc. Oh - and can only be heard with the radio off.
2. A clanking noise which can be heard with the radio turned down or completely off. The clanking noise can actually be "FELT" in the emergency brake handle! I haven't seen anyone with this issue yet. It goes with the speed of the car and at any speed - and can always be felt through the e-brake. I tried slowing down with just the E a couple times and the clank remained there regardless of being pulled or not and same with hitting the brakes, clank remained.
3. Windows loose their indexing - this has happened probably 4 or 5 times now. Re-indexing isn't really an issue - but I did see that there was a bulletin put out with a new computer program needing to be put in for the motors. Just waiting to hear when this fix is available to the dealers.
4. Engine retards timing depending on gas - Okay, so we all know this issue and we know of the fix with the fuses. The problem I have is that it seems to do it from most gas stations I go to - I ALWAYS have put premium in and have NEVER put anything else - and only 93 octane, I make a point to find a gas station with 93 octane. What do I have to do to avoid the retarded timing? I have to fill my tank with premium and then go and buy Octane booster and Water remover Then I get away without having to pull the fuses at any point.
5. Something on the inside of the driver door panel rubs against my glass - whenever I put it down or up there is a streak left about 4 inches from the front (engine side) of the glass on the inside. Passenger side does not do this. It doesn't appear to be scratching, but eventually it will wear it down and I want to get it fixed before I get my windows tinted.
6. Tap Shift has extreme delay (I do NOT know if this is an issue) - it seems that the delay on the tap shift is way too long. When speeding up, if I hit the tap shift say at 4k RPMs it takes until 4.5-4.8k to shift - then the actual shift takes a while (seems like granny shifting a manual) then kicks in HARD - throw you back hard (I like this part, just wish everything was quicker) - let me know if this is an issue or if they are all like this.
7. Remote Start only seems to work about 10 feet away. Doors will lock and unlock from a lot farther but remote start seems to only work when close (almost pointless as far as warming the car up in the winter without having to go almost to it first).
8. Engine CANNOT cool down. This is not an actual issue that a dealer will fix, but I have a BIG issue with it. Idle and engine gets up to 225 (even on a 40 degree day) can only seem to cool it down to 198. Makes for a big problem at the track - 198 degree will run 13.3, 212 will run 13.9, 220+ is in the mid to high 14s. Sucks - gonna fix with a 160 degree thermo and changing the fan timing which shouldn't void any warranty as far as I know because it can't directly cause an issue.
Fixed heat issue with the 160 degree and changing the fans. Refuses to go over 198 now but typically stays in the 170s to 180s.
9. Sluggish acceleration - I believe this is normal on all A6s and maybe all of the 2010 camaros in general due to the coasting/slowing down turning off the fuel injectors. So if you slow down and then hit on the gas it takes a good while to kick over. Let me know if this is not normal, but I hate it.
10. Have to lower my seat to put a helmet on at the race track (had to get 10 )
New Items I forgot about
11. (Technically #10 lol) - Carpet wasn't installed properly - passenger side the carpet is literally an inch away from the plastic piece at the feet - not too happy about this.
12. (Technically #11) - Grinding noise when turning sharp - both forward and back (how could I forget this one)
13. (Technically .... okay you get it) Nice foot plate or whatever it is called at the bottom of where the door is (see it when you open) - think it says camaro lol maybe Chevrolet - anyway, it is starting to peel off on the passenger side - worst part is I rarely have passengers so the door is shut, it isn't like its getting beaten or anything, just bubbling up and coming off *sigh*
14. Trunk sometimes doesn't want to open
15. Passenger air bag detector is a little bit sensitive - put my laptop in the passenger seat and it turns the air bag on (don't really need to protect my laptop with an air bag)
16. Okay - this technically isn't a problem - but has anyone noticed that all of the fuses are always on in the fuse box...wtf
17. Possible blown rear main seal. When installing exhaust noticed oil between engine and tranny. Cleaned off hoping it does not come back and that it was residue from an oil change. I typically wipe it down pretty good so I am fearing the worst right now. Not enough to cause a drip under the car though.
I think that is everything
Vararam CAI, ARH Headers, Flowmaster Exhaust, Nitto NT555Rs, Custom CAM and Tune - 11.981 @ 116.27
IOM - 2SS/RS - Auto - IAP - Sunroof - Ordered 10/13 (#7 at dealer)
3000(accepted to production ): 4/19/09
3300 (scheduled for prod ): 5/11/09
3400 (broadcast ): 5/16/09
3800 (produced ): 5/22/09
4150 (invoiced ): 6/01/09
4200 (shipped ): 6/01/09
5000 (at dealer ): 6/12/09
6000 (delivery to me ): 6/12/09
Last edited by RickyTheStorm; 02-22-2010 at 03:30 PM. Reason: Adding items I forgot
RickyTheStorm is offline   Reply With Quote
Old 11-08-2009, 11:20 PM   #2
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
#5...mine does that too.
#8...if you haven't removed your engine cover you might want to. It will help with removing some of the heat.
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 11-08-2009, 11:42 PM   #3
Silver Ice Man
Silver Ice Man's Avatar
Drives: 2014 2SS/RS Spring limited edition
I have also had the:
#1 issue, and
#3 issue, I didn't hear of any fixes for this yet though
2014 2SS/RS, Spring Limited Edition...
Ask yourself.....when you turn on your car..... Does it return the favor.....
MODS: CIA cold air intake, Oil catch can, Dynatech LT Headers, Dynatech Power cats, Dynatech Cat back exhaust, Janetty racing tune, Vitesse throttle controller, Headlight and marker tint, more to follow....
Silver Ice Man is offline   Reply With Quote
Old 11-09-2009, 12:34 AM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
4, 6, 8 and 9 can be fixed with getting the ecm and tcm tuned
Old 11-09-2009, 01:15 PM   #5
RickyTheStorm
I did remove my engine cover - didn't help much at all - I had a buddy there with his 2010 Camaro, his engine temp held with mine - he had his cover on, mine was off.
Old 11-09-2009, 01:15 PM   #6
RickyTheStorm
#1 issue, and
Did you ever get the #1 issue fixed? If so what was the resolution?
Old 11-09-2009, 01:17 PM   #7
RickyTheStorm
I am planning on getting the HPTuners tuner and taking care of at least the fan times. I am still a little hesitant on tuning other things while under warranty. I know fan times can't void warranty on anything since all it does is help the engine run cooler and doesn't directly impact anything mechanical.
Old 11-09-2009, 01:22 PM   #8
camaro1
camaro1's Avatar
not really, you alter anything in the ecm or tcm even if it is just the fan on time and you can void your warranty
Old 11-09-2009, 01:27 PM   #9
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
Yup. They don't know what you changed, they just know you changed something. (if they check/find out).
UCF w00t is offline   Reply With Quote
Old 11-09-2009, 03:26 PM   #10
Silver Ice Man
No not yet, weather isn't cooperating up here in Alberta.
If I get a nice day I will try to get her into the dealership to see if it is just a heat shield, and to see what the dealer says about the other stuff.
Old 11-09-2009, 11:48 PM   #11
RickyTheStorm
Asked my dealer about it and he said when brought in for anything major they check to see if there were modifications made to the ecm/tcm. If there are, then they have to check the modifications and make sure that it could have actually caused the malfunction to begin with. I asked if I changed when the fans came on if it would be an issue and he said at most it'd just take their time to check the numbers and make sure nothing else was changed, otherwise it won't affect anything. Although I have heard that sometimes it depends on the dealer.
Old 11-09-2009, 11:59 PM   #12
meanmike
Drives: FIRST ON RACE DAY
#6 I am assuming this is the same tranny as on the G8 and it shifted the same way. Even with a tune it will still shift this way, granted it should be quicker but still not immediately. Alot of the guy's still complained about it but once I drove the car for a few month's I could shift it perfectly, you just need too learn when too do it. I really wish I had that tran's in my Stang.
meanmike is offline   Reply With Quote
Old 11-12-2009, 11:02 AM   #13
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Looking at my car there isnt any way for the heat to get out of the engbay they have that sucker sealed off really well.....I know what you mean the car heats up fast and stay hott alot longer than my ls1 did!!!!! poor air flow under the hood i bet
WICKEDSS is offline   Reply With Quote
Old 11-12-2009, 11:13 AM   #14
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
I believe you just need to do the 5, 20 fuse pull. See sticky. Those A6's
are anything but sluggish after this fix was found.
MSRP OR BELOW WITH NO WAITING LIST rkmcmd4 Camaro Price | Ordering | Tracking | Dealers Discussions 8 09-21-2009 01:32 PM
Anyone Waiting @ 1100 For Dealer To Get Allocations talwell Camaro Price | Ordering | Tracking | Dealers Discussions 37 08-27-2009 02:54 PM
Tired of Waiting - Pics of My New Hyundai Genesis Coupe Inspector 17 5th Gen Camaro SS LS LT General Discussions 101 08-26-2009 10:31 PM
Who is still waiting for their engine cover? OHIOSS 5th Gen Camaro SS LS LT General Discussions 7 08-23-2009 12:18 AM
Heard an old rumor: waiting lists! Seanskny Camaro Price | Ordering | Tracking | Dealers Discussions 36 03-04-2008 10:58 PM
