Old 11-11-2017, 10:31 AM   #1
gtpvette
Drives: 2016 C7
Which way does MAF face???
Doing a swap and putting a 2015 LFX into my Scion FRS. That said,, just got the MAF sensor and not sure which way it faces. I would assume the opening faces into the air stream but not sure.
Can someone confirm??
gtpvette is offline   Reply With Quote
Old 11-11-2017, 08:28 PM   #2
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
The way it's oriented in the picture is the same way it's mounted in my Cold air intake. To answer your question ,yes.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 11-12-2017, 08:44 AM   #3
gtpvette
Drives: 2016 C7
Thanks!!!!!!
Old 11-14-2017, 03:29 PM   #4
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
Plus, i think the holes are oriented in the tube for it to fit only one way
kmarshall2121 is offline   Reply With Quote
Old 12-20-2017, 01:18 PM   #5
12blkgrayRS
12blkgrayRS's Avatar
Drives: 2012 Camaro RS 2LT 6spd man
I think there is an arrow on the part orienting the way it's supposed to be installed.
12blkgrayRS is offline   Reply With Quote
Old 12-20-2017, 01:24 PM   #6
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
whoa sounds like a unique build, any photos?
SSEssence is offline   Reply With Quote
Old 12-21-2017, 10:35 AM   #7
gtpvette
Drives: 2016 C7
Build thread is here.
http://www.ft86club.com/forums/showthread.php?t=117334
Should scoot pretty good when done,, FRS is 2750 Lbs so quite a bit lighter than a Camaro. Biggest issue has been with the FRS's rear cross member. Had to get an Oil pan from a Holden out of AU. Also had to recess the clutch master 2 3/4" into the firewall to clear the HP pump on the motor. Motor mounts are done,,, starting transmission mounts and exhaust systems now.
