Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > Canada > Local Marketplace
Old 11-17-2017, 01:11 PM   #1
adarvish
BLAM579
adarvish's Avatar
Drives: '15 ZL1 M6 Black Coupe
FS: 12" Stealth Sub-Box with Integrated Amp Shelf for Coupe Camaro
NEW Stealth Enclosure with Integrated Amp Shelf
(SUB-BOX THAT FITS IN YOUR CAMARO'S TRUNK LIKE A GLOVE)
Provides an added level of convenience to any stealth installation in your 5th Gen. Camaro. It answers the question "Where do I mount my Amp?" By having a nice shelf right on the box, not only is the install much easier, but all the equipment stays together, which saves tons of room in your truck that would otherwise be needed for mounting the amp. Plus, it saves you from buying an extra amp rack to mount your amp. So if you compare the cost of a normal box plus amp rack together, ********’s new integrated stealth is a no-brainer. If that wasn't enough already, as an option, you can purchase the cover plate that attaches to the face of the box and really dresses up your install. There is no other company out there that keeps Camaro Owners needs in mind like ******** does.
Features / Specifications:
· Box Construction: 3/4" MDF
· Volume: 0.95 cu.ft
· Sealed Box
· Amp Shelf Area= 10" x 12.5" x 2.5"
· Cutout Size: 12"=11-1/8"
· Mounting Depth: 10.5"
· Finish: Charcoal Gray Trunkliner Carpet. Very nice OE Match
· Terminal: Installed
· Amp Shelf Cover Plate: None.
· Speakers & Amps: Not Included
*Amp Shelf Size Is Provided Above.
Asking: $200 (CAD) OBO + Shipping. Item is located in Toronto, Ontario, Canada
adarvish is offline   Reply With Quote
Old 11-22-2017, 09:50 AM   #2
adarvish
BLAM579
adarvish's Avatar
Bump
12", enclosures, sub boxes, sub thump, sub woofer
