11-18-2017, 10:56 PM | #1 |
Drives: 2012 ZL1 Camaro Join Date: Dec 2015
Procharger filter placement? Sucking in heat from headers.. Fix?
Has anybody came up with a fix for the air inlet sucking in all the heat right off the header? I was feling around after I had just got done installing my procharger kit and the top side sucks in 100 degrees cooler air it seems and the bottom of the filter is piping hot.
Wonder if wrapping the headers would cool temps down to the air filter? Or possibly making like a sheet metal block right under the air filter to keep the heat from going straight off the header into the air filter... Let me know if you have any better ideas or if any of you procharged guys have done anything about this... Here is a pic of the filter placement I'm talking about...
~01 zO6~ (Procharged/bolt-ons) SOLD
~05 Vette~ (Procharged/Bolt-ons) SOLD ~98 Z28~ (TMS 408/RPM LVL 6/Circle D4k) SOLD. ~00 SS~ (Forged LS/IIHS 7875 Turbo/RPM Lvl 6/Strange S60) 10.3-141 ~2010 SS~ (SLP TVS2300 Blower/Speed Eng LT's) ~2012 ZL1~ (IIHS Twin Turbo) |
11-19-2017, 07:28 AM | #2 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Somewhere in my F-1X build thread there is a pic of the heat shield the shop installed for mine. Also, my aftermarket hood just happens to have a vent right over the ProCharger inlet filter.
Well I just sort of flew though my build thread but I did not see a good pic of the heat shield they installed for mine but it wasn't anything fancy and my AIT is typically only a few degrees over ambient so it must be helping. I pick up the car tomorrow from the Brodix heads install and if I remember I will try to snap some pics for you.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile Last edited by BiggFoot; 11-20-2017 at 09:42 AM. |
11-20-2017, 09:26 PM | #3 |
I promised you a picture so here goes. Not sure how well you can see the shield but it is nothing fancy, but pretty much just a deflector.
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
02-28-2018, 02:09 PM | #4 |
Sweet99ss what is the part # for that big air filter?
02-28-2018, 02:29 PM | #5 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
You run an air-to-air intercooler set up on that don't you? It really doesn't matter how how the air going into the filter is, as the blower will heat it up anyway, and the air-to-air will lower the temps.
What are your current IAT readings going into the engine? That's the important number.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
02-28-2018, 03:22 PM | #6 |
Drives: Camaro Justice Join Date: Jun 2007
Thermal Management
Have the inside of your headers coat and titainium wrap the out side Use their Stage II intercooler that relocates the MAF Install an oil cooler Vent the hood |
03-01-2018, 07:52 AM | #7 |
Just completed new D1X Stage2 Race Intercooler BOV and Inlet Option. It is angled away It did well.
Hope to have it back Sat. Will see if can find a side view. Found one.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly Last edited by SSBUSDRVR; 03-01-2018 at 08:03 AM. |
03-01-2018, 08:33 AM | #8 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
look at some kind of hood venting, per above something right above the filter would be best like the old Z/28's that had the 2 hood vents...thinkin about somethin like that for my ride instead of the 1LE setup...
I also remove that back hood weather strip..let's a sh1t load of heat out...peace
03-01-2018, 01:54 PM | #9 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Not sure if the placement of the ESS Tuning kit (Vortech V3Si) is the same as the Procharger inlet, but here is their solution to sucking heat off the headers.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
03-03-2018, 09:20 PM | #10 |
Based off this pic you don't have a strut bar. I am looking to get the D1x but I am going to have the holley sniper intake manifold so there would be a bit of a difference there. And since you have the stage 2 cooler it should help lower the air temps that are going to your engine a lot better.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries) Procharger D1x with a 3.85 pulley ID1050x Injectors Flex Fuel Sensor Monster LT1 Twin Disk Clutch Holley Sniper Efi Intake Manifold NW 103mm Boosted TB 747rwhp at 12psi on E85 |
03-03-2018, 09:21 PM | #11 | |
What would be the option if you have a stage 2 intercooler. Because since it is so big it will interfere installing an oil cooler decent enough to get the car having lower oil temps as well as lower IAT.
Specs
03-04-2018, 07:22 AM | #12 | |
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly |
03-08-2018, 02:16 AM | #13 | |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
03-10-2018, 07:19 PM | #14 | |
How do you like that kit ?? I am trying to save up for that kit as well and it is tempting just to get the P1x but it will be limited to power. Is your engine forged or is the procharger on low boost ??
Specs
