Old 11-24-2017, 11:01 AM   #1
gtpvette
Drives: 2016 C7
Magnaflow 11386 VS Thunderbolt 1386
I've been gathering exhaust parts for my swap and stumbled across a muffler on EBAY called Thunderbolt TBM1386. It's a dual 2.5" in/out and appears (based on picture) to be an perforated X-Pipe design internally. It's stainless and the EBAY ad compares it to a 11386. Its the same size as well.
I've found it as cheap as $32 so that is about $75 cheaper than the Magnaflow and as I'm bleeding money on this motor swap that's a good amount
Thoughts??? Any one ever use one??
https://www.ebay.com/itm/2-5-Dual-4x...-/142515555787
gtpvette is offline   Reply With Quote
Old 11-24-2017, 11:23 AM   #2
gtpvette
Drives: 2016 C7
Correction to above price. $32 + $12 shipping so $44. Basically the same as Ebay. STill $60+ less than Magnaflow.
Old 11-24-2017, 11:28 PM   #3
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
It looks to have alot rougher finish the Magnaflow. I know the Magnaflow resonated x pipe i installed on my car was auctually pretty heavy. Great build quality. Its what inside that you cant see my be the difference. That cheap one may breakdown alot quicker then the Magnaflow. Its just me but when it comes to exhaust brand names are best. If you look around the forum not many members have cheap no name parts or exhaust. But its entirely up to u.
rontammy0 is offline   Reply With Quote
Old 11-25-2017, 08:05 AM   #4
KillboyPowerhead
Drives: 2015 Z/22
Yeah, seems like a cheap knock-off, especially considering how similar the part numbers are; the cheap one could rust away or degrade in no time.
KillboyPowerhead is offline   Reply With Quote
Old 12-05-2017, 02:38 AM   #5
ghosted
BCS Auto
ghosted's Avatar
Drives: 2015 Camaro 1LS
The main difference is most definitely going to be in the steel and weld quality. Instead of a good stainlesssteel, you're probably going to get some cheap imported stainless steel that'll start corroding rather quickly (especially with the internal moisture caused by our oxygenated gasoline). The packing material is also probably much cheaper, and will likely be less densely packed than the MF 11386. We generally price the 11386 @ $100 shipped since they're a community favorite. Cheap insurance for longevity, I'd say.
BCS Auto on Facebook - - - Follow me on Instagram @datv6tho & @officialbcsauto
ghosted is offline   Reply With Quote
Old 12-28-2017, 06:37 AM   #6
gtpvette
Drives: 2016 C7
Well took one for the team. Quality looks great as do the welds. $47 shipped.
Old 01-14-2018, 10:59 AM   #7
rozarioorlan
Drives: Camaro
How has it held up? What’s the sound quality like?
rozarioorlan is offline   Reply With Quote
Old 01-16-2018, 01:02 PM   #8
gtpvette
Drives: 2016 C7
As this is a swap,,,, not quite there yet. I did start on the exhaust,,, CBM motorsport flanges and a Summit Racing 2.5" exhaust kit. 4-45's, 4-90's, 4 -180's and 4 straight sections. Got the down tubes built (no cats) and with 2 45 sections on each side I'm to the transmission. I'll need to add sone additional straight pipe,, then the 1386 muffler then out the back with twin spiral flow mufflers..
Old 06-26-2018, 09:36 PM   #9
gtpvette
Drives: 2016 C7
Getting closer,,,, LFX to 1386 resonated x-pipe,, back to another x-pipe by the differential as there is no room to make 2 - 2.5" pipes work,, out to spiral flow mufflers. For you that think this muffler is less than it should be,,, just take look,,, nothing wrong that I can see. Remember,, this is an LFX in a Scion FRS
Old 07-07-2018, 10:58 AM   #10
gtpvette
Drives: 2016 C7
done...
Old 07-10-2018, 08:37 AM   #11
tlavoie87
Built Not Bought
tlavoie87's Avatar
Drives: 2010 Twin Turbo LFX
after personally destroying 3 Magnaflow 11386 .. i also grabbed the thunderbolt and so far so good. i figured if im gonna blow em out in a year might as well save a little coin
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014
"Built Not Bought!'
Sponsors:
OverKill Motorsports
tlavoie87 is offline   Reply With Quote
Old 07-11-2018, 07:34 AM   #12
Marklar
Drives: 2012 Camaro LS V6
What do you mean by "blow em out"? What happened that destroyed it?
Marklar is offline   Reply With Quote
Old 07-21-2018, 09:50 PM   #13
rozarioorlan
Drives: Camaro
Looking good so far. I’m sure the power will be nice in a 1,000 lb lighter car! There’s a ton of bolt ons and supercharger available for the LFX so you could be up in the 400’s in that FRS.
Old 07-24-2018, 01:45 PM   #14
gtpvette
Drives: 2016 C7
I looked at that Overkill SC,, nice but pricy. I'm going to wire and install an E85 kit but that will be about it. That said,, car should weigh in at about 2750 and have 325-350HP. Power to weight will be right at what an SS has.
