Old 11-27-2017, 04:05 PM   #1
rmcbee
rmcbee's Avatar
Drives: 2013 ZL1
COPO Hood
I'm playing with buying an Anderson Composites COPO hood for my 2013 ZL1. They recommend a heat shield and hood pins. That would defeat my clean look. I just drive it on the street. Anyone have experience in this area?
rmcbee is offline   Reply With Quote
Old 11-27-2017, 04:34 PM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I got the vfn sonoco. I opted for the lift off, it's held on with dzus fasteners. They sell a bolt on one also, my buddy has one, no pins...super high quality imo...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 11-27-2017, 06:24 PM   #3
Mattzkatz
Mattzkatz's Avatar
Drives: Not yet, but soon
That's what a Camaro should look like. Not much for helping the vision from the captains seat, but it sure helps from outside the car!
Mattzkatz is offline   Reply With Quote
Old 11-27-2017, 06:28 PM   #4
Clarkstar
Clarkstar's Avatar
The way the cowl levels out makes the blockage very minimal...I have no issues
Old 11-27-2017, 06:29 PM   #5
Mattzkatz
Mattzkatz's Avatar
Any issues with heat and loosing the factory hood vents? Assuming yours is the 4"?
Old 11-27-2017, 06:41 PM   #6
Clarkstar
Clarkstar's Avatar
No issues...the cowl is open, cooler under there.
Old 11-27-2017, 07:08 PM   #7
Mattzkatz
Mattzkatz's Avatar
Nice! Looks good...I like it
Old 11-28-2017, 10:27 AM   #8
rmcbee
rmcbee's Avatar
Drives: 2013 ZL1
I see vfn has a *show finish* and *max space* whats the difference, if any?
Old 11-28-2017, 12:08 PM   #9
MudderFinger
MudderFinger's Avatar
Drives: 2011 IOM SS/RS
I have the one from MPD and I like the way it does not slope down in rear. It also works with hinges and no need for pins.
http://www.mpd1.com/content/cam_copostyle.html
MudderFinger is offline   Reply With Quote
Old 11-28-2017, 12:23 PM   #10
Clarkstar
Clarkstar's Avatar
Max space does not have the support across the underside of the cowl...for more intake clearance.
Show finish is smooth on the underside... can be painted.
Mine is the standard sonoco...
Old 11-29-2017, 01:58 PM   #11
rmcbee
rmcbee's Avatar
Drives: 2013 ZL1
you said your friend had a bolt on hood. vfn told me they don't provide a strut for my 2013. I measured my strut at 30 extended and 16 compressed. I have no idea how much my hood weights but vfn said i need a strut to support 25-30 lbs. To get there the only strut I was able to find on orrorr.com was 23 extended and 13 closed. Obviously that 23 aint going to work. Anybody do this before? Tks
Old 11-29-2017, 04:25 PM   #12
rmcbee
rmcbee's Avatar
Drives: 2013 ZL1
Okay I just got off the phone with vfn told the lady I wasn't having any luck solving this strut problem. She says let me go in the back and talk to someone. She comes back...you're strut will work fine as our hood is actually a little heavier. Oh, oh, okay. Let me give this a moment and I'll call you back tomorrow.
Old 11-29-2017, 07:40 PM   #13
Clarkstar
Clarkstar's Avatar
The stock hoods are light...I can't imagine why the strut wouldn't work...
Old 11-29-2017, 08:25 PM   #14
jc615
jc615's Avatar
Drives: Camaro and Sierra
Same I went with and would recommend
jc615 is offline   Reply With Quote
