Old 12-04-2017, 10:43 PM   #1
tazman
tazman's Avatar
Drives: 2014 ZL1
Daly driver
Hello,
I am thinking about buying a ZL1 but it would be my only car I only drive about 6000 miles a year. I live in AZ but we do see some 20 degree weather and I was wondering if that would be an issue for the super charger? Any other things I might need to know about using a ZL1 as a daily driver I would like to hear your thoughts.
2014 ZL1 Roto-Fab intake, 2" TSP headers, JRE 125 package and tune.
2015 2LT RS overkill tune, 80MM throttle body with JacFab spacer, ported intake manifold and Roto-Fab cold air intake. Vitesse throttle controller.
tazman is offline   Reply With Quote
Old 12-04-2017, 11:00 PM   #2
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Just the tires are a concern, as far as I know. You'll need an all season tire to ensure you don't crack the tread blocks when you get below freezing. Also, make sure there is antifreeze in the supercharger cooling circuit in the winter (and not just water and water-wetter).
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 12-04-2017, 11:43 PM   #3
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
SC works even better colder, so much better you will mis the cold, but you will need a good all season if you don't want to wreck it.
ZMEnow is offline   Reply With Quote
Old 12-05-2017, 12:24 AM   #4
608RS
608RS's Avatar
Drives: 2015 2ss
the guys who daily their ZL1 love the bfgoodrich g-force comp-2 a/s tires, might be something you'll want to look into
608RS is offline   Reply With Quote
Old 12-05-2017, 10:02 AM   #5
tazman
tazman's Avatar
Drives: 2014 ZL1
Thanks for the information! I was looking at Super charging my current Camaro and was told the unit could not be run under 25 degrees that is why I asked. I lived in PA and that stopped me from getting the Camaro when I looked at them when they first came out. Now living in AZ I have had no issues with my current car but it has me wanting more I'm just disappointed it will probably be a used one instead of new.
Thanks
Tom
Old 12-05-2017, 11:03 AM   #6
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
I live up north (Michigan) and on a cool day (45 degrees is about as cool as I've gone out due to stock tires), and it runs like a scalded dog. Traction is an issue as far as power, but for comfort, it'll absolutely do. I'd get a set of BFGoodrich Comp 2 A/S and go.
Can'tHave2MuchHP is offline   Reply With Quote
Old 12-05-2017, 12:19 PM   #7
VRZL113
VRZL113's Avatar
Drives: 2013 VR ZL1, M6
I have these on my ZL1 and they are a lovely tire.
VRZL113 is offline   Reply With Quote
Old 12-05-2017, 01:04 PM   #8
sherob
sherob's Avatar
Drives: 2015 SW 1SS/RS 1LE
I see ZL1's and supercharged SS's up here in CO. BFG's are your friend.
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
http://www.camaro5.com/forums/picture.php?albumid=17325&pictureid=134228
sherob is offline   Reply With Quote
Old 12-05-2017, 01:21 PM   #9
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
I just installed G Force 2 in the front and Conti DWS06's in the rear (315's) and couldn't be happier!
JB'sZL1 is offline   Reply With Quote
Old 12-05-2017, 02:23 PM   #10
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by tazman View Post
Hello,
None what so ever.
I have a Yellow 2013 you could purchase.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 12-05-2017, 02:29 PM   #11
squids4daddy
Drives: ZL1 2014
A general comment. I've driven all sorts of cars and trucks as daily drivers at a number of price points. I've driven between 50 and 100 miles per day in a combination of light freeway and very dense freeway traffic for 30 years now. The ZL1 is the best daily driver I've ever had, by far, period.
squids4daddy is offline   Reply With Quote
Old 12-05-2017, 09:37 PM   #12
ZMEnow
Consider the Michelin AS/3 if you can afford. I have run mid 11 secs on them in Low'50 Deg, they hook pretty good in warm weather as well. Very quiet, very soft, but expensive.. I can only compare the sidewall to the OEM super cars which I keep for track days on the OEM rims and the AS/3 doent compare. as far as cold there are few expiences like 35 degrees with a good silica all season and SC..
Old 12-05-2017, 10:53 PM   #13
tazman
tazman's Avatar
Drives: 2014 ZL1
Originally Posted by JANNETTYRACING View Post
None what so ever.
I'll trade you for a 2015!
Old 12-05-2017, 10:55 PM   #14
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
Whats a "Daly Driver"?
Hellfighter is offline   Reply With Quote
