Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 12-05-2017, 10:25 PM   #1
diablo0730
Drives: 2015 Camaro 1LE
Looking for a 3.91 Differential or ZL1 3.73 Differential
As title says I'm looking for either a ZL1 Diff 3.73 with axles or a 3.91 Diff from a 1LE. Let me know what ya got.
2015 1SS 1LE: BTR Stage 5 N/A cam, 1 7/8 Longtube headers, catless connectors, Z/28 Cold Air Intake, Vararam Power Wedge.
Upcoming Mods:
GPI Ported heads
GPI Ported Rodmod intake
ZL1 Injectors
DSX E-85 Flex Fuel Kit
diablo0730 is offline   Reply With Quote
Old 12-08-2017, 12:23 PM   #2
Wacko37
Wacko37's Avatar
Drives: 2010 2SS/RS & 2007 2500HD D-Max
What about a 3:91 from a Z/28?
2010 Summit white SS/RS, Manzo full exhaust w/2" primaries, Roto-Fab intake, FE4 conversion, JRI Coilovers built by Ult_Performance w/hypercoils, BMR sway, BMR trailing arms, UMI toe links, solid sub-frame bushings, upper control arm bushings, radius inserts, caster locks, Taylor wires, BTR spec'd cam, tuned by ECS, various little lighting mods, ebay SLP splitter, Heritage grille, ZL1 rockers, Apex 19x11 w/RE-71r's 305/30/19, eaton tru-trac
2007 2500HD Duramax, Built trans, custom tuned beast
Wacko37 is offline   Reply With Quote
Old 12-08-2017, 11:23 PM   #3
diablo0730
Pm sent
Upcoming Mods:
GPI Ported heads
ZL1 Injectors
Old 12-14-2017, 11:55 AM   #4
diablo0730
Bump
Upcoming Mods:
GPI Ported heads
ZL1 Injectors
Old 12-14-2017, 06:15 PM   #5
Redbeard11
Redbeard11's Avatar
Drives: 11 camaro
Pm sent
2011 1SS/ Thompson mtrsprts 416,Katech rotate assembly and cnc ls3 heads. Ferrera st. valves,BTR 685 Spr. F1A Procharger,3.70 pulley on 12 rib.Holley aux fuel pump,ZL1 fp and fpcm,dual alky control,Vmax TB,DSX E-85 sensor, fic1300 inj.Lsxperts custom cam,melling OP,mishimoto dual pass HX, ARH 2" headers, MD 4l80e, FTI 3200 stall,3:73 zl1 cradle, BC coil overs ,pfadt sway bars, EBC brakes and slotted rotors: 843rwhp tuned by LSXPERTS
Redbeard11 is offline   Reply With Quote
3.73, 3.91, diff, differential, zl1
