Old 12-13-2017, 04:24 AM   #1
Slvr-camaro15
Slvr-camaro15's Avatar
Drives: 2017 zl1 ,2010 SS /RS L99
ARH downpipes with cats & solo catback mach xl. HELP !!!
Hey guys .quick question .I'm in the process of getting the ARH downpipes with CATS to go along with my current solo catback mach xl system . Anything else I might need to do . To get a nice sound / gains / prevent check engine light. Please advise . I appreciate in advance ...
2017 zl1 - rotofab CAI , PDR , Nav .
2010 camaro SS - Procharger D1 sc (Stage 2 with upgraded intercooler)+ whole lot of other goodies ( too many to list )
Slvr-camaro15 is offline   Reply With Quote
Old 12-13-2017, 03:18 PM   #2
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
If you aren't tuned it might be worth grabbing some O2 defoulers for the rear O2 sensors.
DSX_Camaro is offline   Reply With Quote
Old 12-13-2017, 09:30 PM   #3
Slvr-camaro15
No tunes done on the vehicle as of yet . Just bolts ons.solo catback , K&N typhoon CAI. , will have ported 72 mm TB , and vitesse throttle controller . I heard that installing the O2 extensions on the downpipes w/ cats prevents the CEL . I am not sure what the O2 defoulers are ?
Old 12-14-2017, 11:05 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
They're just a threaded extension of the O2 sensors. You can probably just google them, I think? They're easy to put your hands on. And you shouldn't need anything special (I'm pretty sure they make 90 degree defoulers also, unnecessary)
Old 12-18-2017, 08:10 PM   #5
chevyderek72
Drives: 2014 2LT RS
I bought the O2 extensions from big daddies garage. They have an angled one, a straight one, and a mini cat extender. The two first ones are just extenders that pull the sensor out of the direct flow of exhaust. The third one has actual catalytic converter material between the exhaust and the sensor to trick it into thinking a cat is still in place.
The normal extensions were cheap and that's what I used on my ARH high flows. Works great and no cel after a few months and probably 700 miles. The ones with cat material are 100 for two so much more expensive but are a safer bet for keeping the cel light off.
http://www.bigdaddiesgarage.com
chevyderek72 is offline   Reply With Quote
Old 12-18-2017, 08:25 PM   #6
Slvr-camaro15
Wow very helpful ... Thank you !!
Old 12-18-2017, 08:32 PM   #7
Slvr-camaro15
Thanks for the info. From what I read its mainly for cat less applications . I'm getting the ARH Downpipes with cats. So don't knkw uf I will still be needing them.
Old 12-18-2017, 11:29 PM   #8
chevyderek72
Drives: 2014 2LT RS
No problem at all!
I have the exact same thing, ARH pipes with high flow cats. I only have the straight extenders and no cel. So you'll probably be fine with the normal straight ones. If you had the extra cash lying around I'd go for the mini cat ones since you're almost guaranteed no check engine light. But after spending 500 on the pipes I didn't want to spend the extra cash so I went for the basic ones. But like I said no problem with them.
Old 12-19-2017, 04:12 AM   #9
Slvr-camaro15
No problem at all!
That's awesome !!!!!
Old 12-25-2017, 09:41 PM   #10
Slvr-camaro15
Hey guys quick question . Does anyone know if I will need the O2 extensions with the ARH CATTED DOWN PIPES if I am installing the MINI CATS CEL FIX I got from big daddy's garage . ?please advise .
Old 12-26-2017, 03:19 PM   #11
rozarioorlan
Drives: Camaro
I’m sure you’re already aware, but just throwing it out there that technically you really don’t need any additions to prevent a CEL from catted downpipes. Although it’s flowing more freely, there is still a cat in place. It doesn’t hurt to have those mini cats or anything, but not really needed. It is still possible to get a CEL with the catted but from what I have seen it’s really rare.
Also as far as tuning goes, it will be able to clear and make sure you never get a CEL. You also will get the full potential of your car and mods. It may not be something you’re considering now, but is very useful to have.
rozarioorlan is offline   Reply With Quote
Old 12-26-2017, 03:49 PM   #12
Slvr-camaro15
Great points thanks.
