Old 12-13-2017, 09:10 PM   #1
lugnut65
Drives: 12 2SS/RS 45th L99
Fuse pull again
Hey guys,dont bash me for this I know its been covered in detail over and over,i used to have a 2012 ss,traded it in 14,just bought another 12 rs/ss 45th I had a 1ss and I have to say the 2ss is pretty awesome,anyway point is I have no idea in 6 years what kind of fuel they used.I heard some years will relearn without pulling the fuse,and also there is a fuse in trunk that needs pulled IDK got me confused now Is it still a thing Maybe surfed the internet to much
Thanks
12 RS/SS 45th L99,CAI,AND BORLA CB
70 CHEVELLE SS LSX408
lugnut65 is offline   Reply With Quote
Old 12-13-2017, 09:35 PM   #2
Royal Tiger
Drives: 2013 2SS/RS Convertible
Do the fuse pull. It works.
Royal Tiger is offline   Reply With Quote
Old 12-13-2017, 09:49 PM   #3
lugnut65
OK wont hurt,thanks
Old 12-13-2017, 10:55 PM   #4
PeteD
PeteD's Avatar
Drives: 2012 2SS Victory Red with white st
If I can do it, anyone can
PeteD is offline   Reply With Quote
Old 12-14-2017, 09:36 AM   #5
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
Pulling a fuse in the trunk has to do with keeping the NPP valves always open (dual mode exhaust) I'm pretty sure that was only available from '13 thru '15 Camaros, and from '12-'15 ZL1 of course.
nancygrl is offline   Reply With Quote
Old 12-14-2017, 08:51 PM   #6
Spec
Drives: 2010 Camaro 1SS LS3
Just pull the 5 and 20 from the fuse box in the engine bay overnight and reinstall them in the morning. Make sure you've fueled up a few times on 91 plus octane first otherwise the mapping will revert back to lower octane fuel.
You want to make sure you don't have any lower octane fuel in the tank.
Simple as that.
I've got a question though, that someone here can answer;
If your car is tuned, does it make a difference pulling the 5 and 20 if your tune already has a high octane mapping? Does lower octane fuel 'de-tune' your car, or does the tune stay no matter what? Curious...
Spec is offline   Reply With Quote
Old 12-14-2017, 09:58 PM   #7
Aaron0731
Drives: 2010 2SS/RS L99
Simple as that.
I think it depends on the tune... I’m tuned by dynosteve and I asked him if I could run 87 octane in my car even though it’s “tuned” for 91. He said there would be no problems as the computer will adjust accordingly to the lower octane. I haven’t done that yet as in the winter months I always go back to stock tune and run 87. This spring I might try it if gas keeps going up.
Aaron0731 is offline   Reply With Quote
Old 12-14-2017, 11:22 PM   #8
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Simple as that.
Your not alone.. I always wondered this also as my car is tuned and I did the fuse pull stuff when I first got it prior to tuning. Glad you asked and will be interested to see if anyone can confirm.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 12-15-2017, 09:55 AM   #9
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
This is correct Steve leaves the Lower Octane tables (I assume) so the car can adjust for fuel which I prefer in case there is a screw up of some sort. I confirmed this with him as well.
I'm tuned for 94 which I can buy here with no problem but I know if I needed to I could always put in 91 in a pinch. So I assume a fuse pull would be needed if I dropped the octane anytime.
I did try the fuse pull way back but saw no change in the car so it must have been in the high octane tables all along.
qcman is offline   Reply With Quote
Old 12-15-2017, 04:04 PM   #10
InFiD3ViL
InFiD3ViL's Avatar
Correct.
DynoSteve does NOT copy the high octane fuel table over the low octane table.
So if you are DynoSteve tuned, you can still benefit from a fuse pull every now and then.
