Old 12-14-2017, 02:02 AM   #1
hussain112ali
hussain112ali's Avatar
Drives: Camaro V6 2LT RS 2012
Send a message via Skype™ to hussain112ali
Exclamation AC Off Due to High Engine Temp !
Hi there ...
Today I started my car in the morning ... and this message pop-up :
"AC Off Due to High Engine Temp"
and the Coolant Temperature is showing --
when turn the engine off the coolant fans keep ruining like 10 mins
So what is causing this and what I should do about it !
hussain112ali is offline   Reply With Quote
Old 12-14-2017, 04:00 AM   #2
samgray20
samgray20's Avatar
Drives: 2010 CGM 2SS/RS M6
You should definitely check your overflow and radiator to see if you have coolant in them. Check for leaks, flow, etc. If all seems well then I'd say you might have a bad ECT sensor.
Sent from my SM-N950U using Tapatalk
2010 CGM 2SS/RS M6 - Comp 227/243 .620/.612 | Nitrous Outlet Plate Kit - 100 Shot | ARC Bottle Bracket/Heater | NOS Progressive Controller | AEM Wideband | Kooks 2"x3" LTs | 3" Custom Catback | CAI Intake | Bo White PTB | Billet Motor Mounts | Hurst Short Throw | McLeod RXT | RAM TOB | 3.91 W/ Eaton Truetrac, LPW Cover, Poly Bushings, GForce 850HP Axles | Eibach Pro-Plus Kit | Whiteline End Links | Hotchkis Tower Brace | ZL1 Front End | Blue Powder Coated Calipers | Vorsteiner V-FF 101 - 20x11 and 20x10 | M/T Street Comp - 305/35 and 275/40 | 2 JL Amps | Diamond Audio Speakers | JL Stealthbox
samgray20 is offline   Reply With Quote
