![]() Drives: 1992 LS3 Typhoon Join Date: Jul 2017
Fuel Rails For Maggie 2300
Ran into my first issue so far... I bought a set of LS3 Fore fuel rails to go with my Maggie set up and they won’t work. The Maggie rails have (3) mounting points on each rail and the Fore only have (2).
Are there any options for aftermarket rails, Maggie 2300, and OD rear cog? |
#2 | |
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq |
#3 | |
If I can’t find something to work I will have to go with the notched Maggie rail. Last edited by Fatal Ty; 12-18-2017 at 12:48 PM. |
#4 | |
![]() ![]() ![]() ![]() Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
I had a Maggie with OD cog, E-85, and 795 rwhp and the Maggie fuel rails were still good. Only went with Fore fuel rails when I switched to the F-1X.BTW Sanner . . . nice wheels!! They look very familiar.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
![]() Drives: 2003 corvette Z06 Join Date: Jan 2014
Search “nasty performance “ , they have Black anodized rails for the 2300
#6 |
Thank you. I am going call them today to see if there rails clear the OD rear cog set up.
#7 |
After a lot of thread searching I found out that the Nasty rails won’t work with the OD rear cog set up. Ordered the modified Magnuson rail and will buy a block off plate for my return style file system, hopefully I won’t have leaking issues.
