12-16-2017, 01:35 PM | #1 |
Drives: Rs 2011 Join Date: Jul 2017
Issues EveryWhere I need help ! 2011 Camaro
you guys have help me out a lot
hoping for the same luck again.. First issue.. My key-less start don't work anymore when i press it, i just see blinkers but it doesn't start the car. second problem... My AC blowing hot Air I had a mechanic check it but i don't know if he is knowledgeable with the issue... I have Freon he check the compressor, compressor is good but it's not powering on he then went to check the fuse box underneath the hood all work but some relay thingy that looks grey said no ground power was coming in ... cant fully remember hoping you guys have some ideas or can help me out with the tad bit of info... |
12-16-2017, 03:08 PM | #2 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Sounds an awful lot like its your BCM (Body Control Module). When these things go, very strange things happen.
12-16-2017, 04:03 PM | #3 |
I know remote start will not work if there are any 'recorded' issues with the car. If you throw a code, for instance.
You are not getting any codes or dash warnings at all?
12-16-2017, 04:36 PM | #4 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
Several things could cause the A/C not to work. Is it actually blowing hot air or just non air conditioned air?
12-16-2017, 07:09 PM | #5 |
Drives: 2012 45th Anniversary Camaro 2LT RS Join Date: Oct 2017
Is your check-engine light on? That will prevent the car from remote-starting.
12-16-2017, 10:05 PM | #6 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
start at the beginning...how old is that battery?
12-17-2017, 09:09 AM | #7 |
old school chevy rodder
same here the battery is most likely toast, your a/c ground may need cleaning up and sounds like you have a gremlin in opening up the trap doors all heating/cooling systems have...most systems operate off of little vacuum hoses and little diaphrams.....
12-20-2017, 02:57 PM | #8 |
I haven’t fix issues yet I’m gonna have another mechanic work on it
I have a few lights on but it doesn’t say anything about the AC |
12-20-2017, 03:08 PM | #9 | |
Just an average Dude
Drives: 2015 1LT Grey w/Orange Rally Stripe Join Date: Mar 2016
So far I like my car the way it came from the factory.
