Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Exterior Parts & Accessories
Old 12-21-2017, 03:03 PM   #1
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
2010-2015 Camaro CoverKing Autobody Armor Car Cover
2010-2015 Camaro CoverKing Autobody Armor Indoor Outdoor Car Cover From $399.99. Use Code PHIL5 At Checkout And Save
If you are looking for an indoor/outdoor car cover Coverking's Autobody Armor offers maximum protection for both indoor and outdoor use. This custom car cover is built with three layers of fabric to create a strong barrier against water, UV rays, dirt, dust, animal droppings, and other pollutants. All the fabrics used for this car cover are made from breathable materials to eliminate condensation under the cover. To further protect the paint of your car, Coverking added a soft fleece liner for a super soft enclosure around your 2010-2015 Camaro. This Autobody Armor car cover is manufactured to the exact specifications of your 2010-2015 Camaro with mirror and antenna pockets included. This custom cover will fit your 2010-2015 Camaro like a glove.
https://www.rpidesigns.com/shop/item...oor-car-cover/
Our Autobody Armor Custom Car Cover is a unique, industry-leading, multi-purpose cover that is both lightweight and extremely durable. Manufactured to the exact specifications of your vehicle, this cover provides the best all-around protection against extreme weather.
Perfect for those who may need to leave their vehicle outside for extended periods of time or to keep it safe from dings and scratches in the garage this Autobody Armor car cover can do it all. This cover can be used both indoors and outdoors.
Each CoverKing Stormproof cover is made with your specific vehicle in mind including mirror and antenna pockets to create a complete custom fit. This cover will provide great indoor and outdoor protection for your car.
Three layers of material for maximum protection
Outer layer of woven polyester for maximum protection
Durable inner polyurethane layer for maximum water resistance
Soft inner lining to protect the finish of your Camaro
Highest level of UV protection and water resistance
Custom-fit styling to the exact specifications of your Camaro
Special neoprene elastic tensioners in front and rear to hold the cover firmly in place
Includes covered grommets for use with optional cable and lock kit
Mirror and antenna pockets included
Manufactured using Coverking's unique double-stitching and waxed thread technique to virtually eliminate leaks
TRUE CUSTOM PATTERNS
Like a fine suit, your cover is made to fit the curves and features of your vehicle. Our designers spent time with your model vehicle and used 3D scanners to record every compound, curve, and detail. That data is used to create a world-class cover with the fewest seams possible. Custom mirror and antenna pockets are sewn in to allow the cover to rest perfectly on your vehicle’s exterior.
THE COVERKING ADVANTAGE
Coverking designs its own fabrics and works with the world’s leading textile mills to handle manufacturing. With quality assurance teams dedicated to checking every batch of fabric, Coverking ensures that the material used in our products meet the most stringent assessments. We check to see if our material is breathable, allowing for the proper release of moisture. We exposed our fabrics to intense UV rays to make sure our fabrics do not fade over time. We go through a series of stress test to make sure the materials hold up for everyday conditions. Above all, our covers are checked before reaching our customer to ensure quality.
RPI Designs is offline   Reply With Quote
Old 10-28-2019, 03:23 PM   #2
RPI Designs
