Old 12-22-2017, 09:07 PM   #1
bses48
Drives: 2010 camaro 2ss Kooks 1/78 btr3 391
carbon fiber driveshaft
Thing about getting a carbon fiber drive shaft, have a 2010 Camaro 2ss kooks long tube headers hi flow cats no mufflers, 391 gears, trailing arms and bushings, need your advice, bses48
bses48 is offline   Reply With Quote
Old 12-22-2017, 09:21 PM   #2
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
What are you looking to get out if it? You will shave weight from rotating mass.
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 12-22-2017, 09:27 PM   #3
bses48
save weight, more power to wheels, revs faster
Old 12-23-2017, 12:22 AM   #4
gm2376
gm2376's Avatar
I woont put any more power to the wheels.
Old 12-23-2017, 06:52 AM   #5
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
Technically you're right and wrong. It won't add any more power to the engine, but it should eliminate some the of the hp/tq loss to the wheels. Not enough to actually feel, but there will be less lost.
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 12-23-2017, 09:16 AM   #6
christianchevell
old school chevy rodder
christianchevell's Avatar
I would save your money....I am on stock axles but I don't hammer it as its all about the torque and getting some grip......MY mods are in my sig. And getting power to the ground I may go to a one piece aluminum and zl1 rear someday but stock its staying alive really well with the trailing arms and toes done up and my power level and driving style.
Old 12-31-2017, 08:58 AM   #7
STALKER
STALKER's Avatar
Drives: 2023 Camaro ZL1 1LE
Nice mods. How much power are you making with that set-up?
OP, I would say if you have the money to spare, do it, but if you don't, your money is probably better spent on something else if you are only lightly modded over stock.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler
2023 Camaro ZL1 / 1LE
Stock
STALKER is offline   Reply With Quote
Old 12-31-2017, 10:03 AM   #8
christianchevell
I make about 490 torque and 485 hp to the wheels. wide range on the rpm down where I use it go to 5 grand.. Some day a better cam, ls7 heads, intake, 102 etc I will make a lot more.... just taking it easy..LOL torque is what moves you in a heavy chevy or any other ride////
Old 12-31-2017, 11:28 AM   #9
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
what kind of tune on the car? cai? sub-frame bushings? lot's to do before a drive shaft IMHO...LPW rear diff cover, you got D/R's?
your want faster rev's get a new clutch that weighs less..good luck OP.
Old 12-31-2017, 12:19 PM   #10
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
I was at a car show and the drive shaft company was there with a booth. Met the owners and crew , they are a great group of people. I asked a few questions as I was really interested in carbon fiber drive shaft as well.. after speaking with them and was provided great knowledge from them I found and was told the better choice for the gen5 is the aluminum drive shaft over the carbon fiber one. So down the road when the time comes I will listen to them and go with the aluminum one. Just putting what I learned from them out there for you.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 12-31-2017, 12:20 PM   #11
Bo White
Bo White's Avatar
https://youtu.be/hjErH4_1fks
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 12-31-2017, 12:30 PM   #12
Jayjellyfish212
Drives: 2014 1LE
Bo that video was great! Amazing how strong simple fibers can be made into parts.
Old 12-31-2017, 01:45 PM   #13
Bo White
Bo White's Avatar
No doubt. I posted this in the drivetrain section a while back.
Totalled:
Old 12-31-2017, 04:03 PM   #14
STALKER
STALKER's Avatar
Stock
