Old 12-25-2017, 12:15 PM   #1
diablo0730
Drives: 2015 Camaro 1LE
KB 2.8 safe to baby to tuners?
As title says I have a 2.8L Kenne Bell I'm putting on my Camaro with a built engine. Car is cammed also and on a street tune and running a little rich. Would I be able to put the KB kit on it and baby it to the Dyno that's about an hour away? I'd like to have it on since I need a tune/calibration anyways for the 3.91s I just did on it so would like to have it all done at once.
2015 1SS 1LE: BTR Stage 5 N/A cam, 1 7/8 Longtube headers, catless connectors, Z/28 Cold Air Intake, Vararam Power Wedge.
Upcoming Mods:
GPI Ported heads
GPI Ported Rodmod intake
ZL1 Injectors
DSX E-85 Flex Fuel Kit
diablo0730 is offline   Reply With Quote
Old 12-25-2017, 12:16 PM   #2
hou30guy
Drives: 2011 convertible 2ss/rs
Yes stay out of boost
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 12-25-2017, 12:40 PM   #3
diablo0730
With the stock injectors or put the bigger ones in it?
Upcoming Mods:
GPI Ported heads
ZL1 Injectors
Old 12-25-2017, 12:42 PM   #4
hou30guy
If u got hp tuners and know how to do the injector data yes bigger ones if not then no. Or if u have hp tuners at ur tuner for a startup file with the bigger injectors
Old 12-25-2017, 12:49 PM   #5
diablo0730
Nope i don't have HP tuners yet.
Upcoming Mods:
GPI Ported heads
ZL1 Injectors
Old 12-25-2017, 12:49 PM   #6
hou30guy
Stay out of boost then
Old 12-25-2017, 02:56 PM   #7
scv_guy
scv_guy's Avatar
Drives: 2010 Camaro SS
Yes no problem, just baby it!
scv_guy is offline   Reply With Quote
Old 12-30-2017, 02:26 PM   #8
cc-rider
Be aware that it’s hard to stay out of boost with a PD supercharger. They are always making boost. You neee to really baby it and accelerate slowly. I assure you if you step on the accelerator and open up the throttle body that bypass will slam shut and you’ll see full boost instantly. Another way to ensure this is to just disable the bypass. Tie wrap it open. Or unplug the boost lone going to it. Then it won’t go into boost.
BTW. I’ve got a KB 2.8 on my Camaro. Installed it myself. And I tune myself. . Happy to help if you have any questions.
cc-rider is offline   Reply With Quote
blower, built, dyno, kenne bell, tune
