Old 12-25-2017, 09:16 PM   #1
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
Havoc Rear Diffuser
does this diffuser need to be painted? I am looking for it to be that same flat black color as the stock diffuser. Does it come with a primer coat, or is it already a flat black.
thanks
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 12-26-2017, 08:13 AM   #2
hesster
hesster's Avatar
Drives: '10 T/A Conv, '10 2SS, '77 SE T/A
It has to be painted, at least mine did. It comes with a basic primer on it and a little scuffing and detailing will get it ready for paint. They do not fit real well in some cases, it is essential that the retaining tabs are fully seated. I tweaked mine to fit quite good.
hesster is online now   Reply With Quote
Old 12-27-2017, 08:19 AM   #3
inglopez19
Drives: Camaro 2010 SS
This one looks so good ! You order the middle part carbon fiber right ? Or did you did the carbon fiber wrap ?
inglopez19 is offline   Reply With Quote
Old 12-27-2017, 08:50 AM   #4
hesster
hesster's Avatar
I got the CF option on the insert, and clear coated it to make it pop, as the hydro dipped insert is a little "dull" in my opinion. I also did not like the fit of the insert at the top center as it was not flushed out to my liking, so I epoxied a small spacer under the lip of the insert to the larger diffuser panel, pushed it together for an hour with a propped up chunk of wood, and that got it almost perfect.
Old 12-27-2017, 10:42 PM   #5
Low Saturn
Low Saturn's Avatar
Drives: 2011 Camaro 2SS/RS
The outer part needs to be painted. But before you paint it, get the fitment dialed in. Mine took a lot of work to fit correctly and I ended up having to repaint it.
Also my "carbon fiber" center section wasnt formed correctly. Took quite a while to get a replacement. But all is good now.
Low Saturn is offline   Reply With Quote
Old 12-28-2017, 05:48 PM   #6
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Once I got the bumper off, this one installed in 15 minutes and needed no "alterations" to make it fit.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 02-07-2018, 01:01 AM   #7
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
What one is this? The eBay shark fin?
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
TwentyTen2SSRS is offline   Reply With Quote
Old 02-07-2018, 01:41 AM   #8
cnrad
cnrad's Avatar
Drives: a wagon
Yup, made by Ikon Motorsports.
https://www.ikonmotorsports.com/10-1...yurethane.html
cnrad is offline   Reply With Quote
Old 02-15-2018, 03:58 AM   #9
TwentyTen2SSRS
Drives: 2010 2SS/RS
Originally Posted by cnrad View Post
Oh nice it looks rad if I just didn’t have quad tips
