Old 12-29-2017, 11:18 PM   #1
error3rror
Drives: 2011 Chevy Camaro LS
Help ! my car won't start fast
i had to jump start my vehicle in order for it to turn on. i'm not sure if i need a new battery already or it just needs more charge.
when i turn the engine , it slowly starts,then on the dashboard it keeps saying to open and lower my driver window.
i was out on an army duty for 3 months,not sure if my relatives drove my vehicle.
any suggestions on what to do?
error3rror is offline   Reply With Quote
Old 12-29-2017, 11:23 PM   #2
motorhead
Sounds like you need a battery especially if that is the original. You car is seven years old, and if it was allowed to go dead it most likely is done.
Old 12-29-2017, 11:42 PM   #3
StreetRage320
Those who need me got me
StreetRage320's Avatar
Drives: 2022 ZL1 A10
Check your battery voltage must be above 12.5 volts, clean terminals.
StreetRage320 is offline   Reply With Quote
Old 01-11-2018, 04:38 AM   #4
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
I've had to replace my battery 3 times so far. I live in Tucson, AZ and that plays a role in the battery failure, hot temps are not good on batteries. I was also getting the reset the driver side window issue. The new battery stop this until the battery started going south again.
I have 56k miles and just replaced the wires and spark plugs. The electrodes on the plugs were very worn. Starts and runs much better now.
I'm also going to but a Dyna Force MSD starter, turns the car over much quicker and doesn't cause a huge drain on the battery like the stock starter.
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 01-19-2018, 11:54 PM   #5
TWOFORTYZ
Drives: 2015 Camaro 1SS 6M
Unless they have reinvented the wheel, most electric motors are similar in efficiency. This would not be a cost effective modification. Around 746 watts is required for 1 horsepower. There is no magic starter motor that strays from this concept, unless perhaps it has a large capacitor to store the energy and therefore has a lower perceived inrush current.
3 months is not unreasonable for a battery to discharge. Charge it and see what happens, running the car for normal period of time will NOT fully charge a battery, even with a 160 amp alternator. On average it takes me around 100 miles of freeway driving to fully recharge a flat battery. Just because the car starts does not mean it is charged... Check voltage, or plug into a battery charger to confirm my statement.
TWOFORTYZ is offline   Reply With Quote
Old 01-20-2018, 07:06 PM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
If you have a 2011 with original battery, you need a new one, no matter what. And next time, use a Battery Tender, not relatives, to preserve the battery when you are away.
Rock-It Man is offline   Reply With Quote
