![]() Drives: 73 nova custom, 2ss ordered Join Date: Jul 2009
First oil change for LS3
At what milage do you think the first oil change should be, i wonder if I should change it sooner than the recomended interval
![]() ![]() ![]() ![]() ![]() Drives: 67 Camaro Convertible Join Date: Jun 2009
If you do a search, there have been numerous threads about this. I think you will find that most people changed their oil earlier than later. I have a 2LT, changed my oil at 1,400 miles and again at 2,900 miles. I'll probably change it every 5,000 from now on, no matter what the oil life monitor says.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, SunroofPlaced order at dealer 4/24/09 1100 - 4/28/09 2000 - 5/01/09 2500 - 5/05/09 3000 - 5/05/09 3300 - 5/30/09 3400 - 6/05/09 3800 - 6/18/09 4000 - 6/18/09 4B00 - 6/18/09 4200 - 6/22/09 5000 - 7/01/09 6000 - 7/01/09 It's Home!! 0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less |
Banned
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
I'd be cautious about changing the oil TOO early - most modern engines have a special lubricant applied at the factory during assembly which they advise to keep in the engine for a certain period of time. Double check your owners manual, as it may say not to do your first oil change untill the DIC advises so. And then after that change it whenever you want to.
Choke on that causality!
Drives: 2010 2SS/RS Join Date: Sep 2009
Its a good idea to change the oil after the initial engine break-in. Most people seem to be doing it no later than the first 1500 miles.
![]() Drives: 2010 2SS RS IBM 6M w/gfx Join Date: Jun 2009
Changed it at 840 miles (before storing it for winter).
#6 |
Bring It
1450 miles here.
#7 |
678 miles
#8 |
Live to Win, Dare to Fail
Drives: 2010 Aqua Blue RS/SS M6 Join Date: Nov 2008
I changed the oil in my LS3 at something like 1800 miles.
3/13/09 - Ordered Aqua Blue Metallic 2SS/RS M6! 7/13/09 - Built! 8/11/09 - Delivered! 2G1FT1EW2A9124579 |
#9 |
Institutionally Insane
Check my thread on Blackstone Labs in the Maintenance/Break in section.
Changed at 980 and roughly 3100 and still had high levels of copper, silicon and aluminum after the second oil change. Although normal, my belief is that by getting most of it out as fast as you can, the better the entire rotating assembly will wear in the future. Will driving the car with increased amounts of silicon, copper and aluminum damage the engine if you go 8-10k on the original oil from factory? I would rather not find out. My OLI stated I had 8500 miles left on my factory fill when I changed it at 984 miles. I am using Pennzoil Platinum and Mobil1 fiilters. PP has a better additive package (zinc/phosphates/calcium/magnesium) than Mobil1.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
#10 |
![]() Drives: 1995 z28 - 2000 SS - 08' vette Join Date: Nov 2008
Mobil 1 oil and filter every 5000.
#11 |
![]() Drives: 04 sentra, 2ss Join Date: Apr 2009
Ls3 i changed it at 1500 then @ 3000 then maybe 6500 i use the recommended oil and moble 1 oil filter
#12 |
![]() Drives: 2010 IBM SS/RS Join Date: Aug 2009
I think it says 6k in the manual,I asked around and heard similar statements to fastballs' post
#13 |
Comic Curmudgeon
Drives: 2010 Camaro 2SS-2010 VW CC Sport Join Date: Mar 2008
Changed mine at 1450 miles. Mobil 1 only.
Will do again this weekend at 3700 miles. I am just that particular about my car. I have a Grand Prix GTP with 120,000 on it and chage it every 3,000 miles, runs like new.
Member Illinois Camaro Club
His Name is Rosie - "Speak Softly and Carry a Big Stick!" - If you know who said that, then you know the genesis of his name. |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 Sonic, 2010 Camaro SS Join Date: Jan 2009
I changed the oil on my LS3 at 2977. Installed new Pure One oil filter and fresh Valvoline full Synthetic. Baby runs great. From now on I will probably change every 5-7k. I don't daily drive it so I should be good with this plan.
| Oil Capacity LS3 | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 77 | 04-21-2014 10:19 PM |
| best synthetic oil to use | hollywoodjose | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 130 | 01-26-2014 08:51 AM |
| Oil temp after change | rtcage | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 11 | 10-21-2009 12:38 AM |
| 3,000 Miles - No "Metal Shavings" - Anyone Else? | FNKNSTN | 5th Gen Camaro SS LS LT General Discussions | 48 | 10-05-2009 11:46 PM |
| Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
