Old 01-08-2018, 09:19 AM   #1
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Are 1LE rear shock mounts required for 1LE shock upgrade?
Hey all,
So I have seen different opinions on this, but I have some 1LE shocks/struts ready to go on, but do I NEED the rear 1LE shock mounts to install the 1LE shocks, or is it just the preferred method?
Thanks!
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 01-08-2018, 10:56 AM   #2
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
If you have a 2010 I would say yes. If you have a 2012+ w/FE4, maybe not. I replaced them when I installed them on my 2013 and can't remember if the part nos were same. I would regardless as the bushings age.
Also check - you might need to install the 2012+ FE4 lower control arms for those shocks. The mount points could be different.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 01-08-2018, 11:46 AM   #3
xc_SS/RS
Drives: 2010 Camaro SS/RS
i don't think it is 'required' but it is definitely recommended. the ZL1/1LE rear shock mounts are an upgrade over the FE3 or FE4 pieces.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 01-08-2018, 05:52 PM   #4
Synner
Drives: cars
There's not much difference when I had both in my hand at the same time and did measurements. Same durometer but slightly more surface area contacting the washer.
Old 01-08-2018, 08:31 PM   #5
LCPLPunk
USA-1
LCPLPunk's Avatar
Synner, thanks man! Looks like I can save the money then and put it towards a ZL1 rear sway!
Old 01-09-2018, 08:27 PM   #6
JusticePete
Drives: Camaro Justice
The better choice would be the Z/28 mounts IMO
Old 01-09-2018, 09:37 PM   #7
LCPLPunk
USA-1
LCPLPunk's Avatar
Oh boy, didn't know that was even an option! Do you know the part number and cost? What makes them better?
Old 01-09-2018, 10:15 PM   #8
JusticePete
The hour glass shaped rubber bushing is harder, denser.
22836727 / 22836734
Old 05-05-2021, 10:45 PM   #9
rich2342
rich2342's Avatar
Drives: 2010 CGM Camaro SS
Bumping an old thread.
I recently installed Z28 rear mounts on my 2010 SS with 1LE shocks/struts on Hotchki 1 inch drop springs.
There seems to be more rake and the wheel gap in rear seems higher?
Is this due to the Z28 mounts thickness or the 1LE struts?
rich2342 is offline   Reply With Quote
Old 05-06-2021, 06:46 AM   #10
KillboyPowerhead
Drives: 2015 Z/22
How much higher was the rear than the front before the install compared to after? Rear sits a bit higher than front from factory. Were all of the bushings "timed" properly during install? Torqueing the suspension arm bolts when the arms are not in their resting position (car on the ground) will create extra tension in the bushings when the car is on the ground, causing the chassis to sit higher than it should.
KillboyPowerhead is offline   Reply With Quote
Old 05-06-2021, 03:34 PM   #11
rich2342
rich2342's Avatar
They were done by a professional. Sure he did that.
I think the Z28 hats have a thicker bushing which probably accounts for the difference. I was hoping to see if that is fact and any remedies
