Old 01-09-2018, 10:18 AM   #1
rviper24
rviper24's Avatar
Drives: 2013 Camaro SS 6-Speed
Question Looking to remove RS chrome trim on 14 ss
Anyone remove the chrome trim on the front grille and headlights?
I've seem people replace the grille with the z28 grille and it looks great but they leave the chrome trim around the headlights.
I know there will be a visible hole on each side but anyone else just say screw it and removed all the chrome trim?
2013 Camaro 1SS 6-Speed LS3
All stock.. For now...
rviper24 is offline   Reply With Quote
Old 01-09-2018, 10:46 AM   #2
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
I dont think you can remove the chrome trim on the headlights because it will leave a void. Most people just wrap the trim above the headlights and delete the center for the z28 grill.
SSEssence is offline   Reply With Quote
Old 01-09-2018, 07:56 PM   #3
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
+1.
I've read threads about this and they just wrap the Chrome into a different color.
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported 821 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, DSX aux pump, zl1 in tank. deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 01-09-2018, 09:27 PM   #4
nty1234
nty1234's Avatar
Drives: 2015 2SS Summit White
I just did the rs conversion today on my non-rs ss. No hole for me since it did not come with the hid's from the factory. (The factory rs models will have a small rectangular hole on the corner. I'm not sure how much this picture will help but this is without the chrome trim, their is a small led strip at the very top that serves really no purpose as it does not light up. Curious why gm put that there in the first place if anyone knows? anyways you only notice it if you sit down as in the way this picture was taken. I also have the z28 grill (mine came with it from the factory)
nty1234 is offline   Reply With Quote
Old 01-09-2018, 10:42 PM   #5
SSMY1LE
SSMY1LE's Avatar
Drives: '14 1LE RS NPP Recaro
I used "black out tape" (sold at most car parts places). Took me 10 minutes and can be removed in seconds at anytime.
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be
SSMY1LE is offline   Reply With Quote
Old 01-10-2018, 12:48 PM   #6
rviper24
rviper24's Avatar
I think I might try removing the trim and cover the holes with black vinyl
Old 01-10-2018, 02:05 PM   #7
nty1234
nty1234's Avatar
I will get a picture up close in the day time later today and post it up so you can get a better idea.
Old 01-10-2018, 02:44 PM   #8
nty1234
nty1234's Avatar
Here you go.
Old 01-10-2018, 03:57 PM   #9
rviper24
rviper24's Avatar
I think it looks so much better without the RS chrome trim
Old 01-10-2018, 04:03 PM   #10
nty1234
nty1234's Avatar
I agree, although with them blacked out they are a lot harder to see and look pretty good, but it just bugs me on the headlight chrome strip where it bulges if you look at it from the side.
Old 01-10-2018, 04:40 PM   #11
608RS
608RS's Avatar
Drives: 2015 2ss
looks great! how did you apply around the curved edges of the headlight?
608RS is offline   Reply With Quote
Old 01-10-2018, 05:04 PM   #12
SSMY1LE
SSMY1LE's Avatar
Divided the chrome into sections, easier to handle this way. The vertical one just wraps around the back. Used a plastic putty knife to smooth it.
Old 01-10-2018, 05:35 PM   #13
608RS
608RS's Avatar
Drives: 2015 2ss
thanks!
Old 01-10-2018, 05:52 PM   #14
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
When I had my '15, I plasti-dipped the chrome trim.
nancygrl is offline   Reply With Quote
grille, rs package, z28
