![]() ![]() Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
Ss auto driveshaft carrier support bearing R&R?
Any fourms or instructions or video on this changing out part
![]() Sent from my SM-N950U using Tapatalk |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I’m in the driveline business and although I haven’t personally seen our Driveshaft out of the car, I asked one of my biggest customers the other day how many failed center bearings he’s seen in Camaros. His reply was, ‘not too many but they’re non replaceable bearings.’ Sadly, many of today’s Driveshaft’s are non serviceable. They ‘want’ you to buy a new one from the dealer.
Check with The Driveshaft Shop who is a sponsor here or Powertrain Industries, Inland Empire Driveline or maybe someone local like Houston Drivetrain. Many of my customers find solutions to ‘non serviceable’ driveline problems. If they don’t, some offer complete shaft replacement for less than a dealer charges.
The dealer sales the bearing 75 bucks, i seen a couple of youtube videos of the holden,commador driveshaft looks the same as our ss . And its a snap ring that holds the bearing in place thats it. Non press in
Sent from my SM-N950U using Tapatalk Last edited by hou30guy; 01-09-2018 at 05:09 PM. |
Gm part number 22810753. I think the only reason it broke was motor was out 5 months and trans was leaning. Transmission mount rubber was broke which probably cause the bearing to go when i got it back together and running
Sounds like the center u-joint is non replaceable and staked-in. There may be a way to remove the bolt holding the midship yoke on without removing the joint. Sounds shaky to me.
#6 |
There is no bolt on ours, when u pull the 2 pieces apart the carrier bearing is on the spline side and slide off thru the spline. Its held in place by a snap ring.
https://yputu.be/6ZShTnWebZE Sent from my SM-N950U using Tapatalk |
#7 |
The g8 driveshaft should be the same as ours , check the video out
#8 |
I can’t make that vid load.
#9 |
Look up g8 ss caprice center support bearing replacement on youtube
#10 |
Well, that looks easy enough. I wonder why two of my customers in the business didn’t describe this kind of shaft/bearing when I asked them? Something must be different.
#11 |
Its not often they go out so most never repaired them
#12 |
My car been sitting without eng so trans was leaning no support so i did my own damage
#13 |
Dealership sells them 75 so they are serviceable and only a snap ring holds them
#14 |
Well ill see how this goes today
![]() ![]() Sent from my SM-N950U using Tapatalk |
