Old 01-09-2018, 11:59 PM   #1
JosefJamesRS
Drives: 2011 LT1 RS
Smile Ground Effects Package Questions!
Hey everyone, I have the ground effects package and was wondering how much it would sell for if I tried to get rid of it. It's unpainted and used although it is in very good condition with minimal damage. On another note, I was considering getting rid of just the ground effect side rockers and rear, and keeping the front splitter but I'm not sure how good it would look, any input or pictures would be helpful. I'm new to the forum so any help is appreciated, thank you very much.
JosefJamesRS is offline   Reply With Quote
Old 01-10-2018, 12:01 AM   #2
Cupidsrage
Drives: 2010 1LT camaro
i need some rockers what do they look like?
Cupidsrage is offline   Reply With Quote
Old 01-10-2018, 12:24 AM   #3
JosefJamesRS
Drives: 2011 LT1 RS
Old 01-10-2018, 08:20 AM   #4
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
I paid $1,000 for a new in box set of unpainted ground effects this last summer. That should give you a starting price point.
Check out my build thread
Old 01-10-2018, 09:26 PM   #5
rwhxk3
S1N1STR
rwhxk3's Avatar
Drives: 2013 Camaro 2SS
Is it a GM GFX package?
Sent from my iPhone using Tapatalk Pro
rwhxk3 is offline   Reply With Quote
Old 01-11-2018, 05:00 PM   #6
JosefJamesRS
Drives: 2011 LT1 RS
Yes, it is.
Old 01-11-2018, 10:43 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
Keep in mind the GFX front splitter for the V6 models is different than the V8 versions.
The rest of the set it identical between versions.
Old 01-11-2018, 10:58 PM   #8
rwhxk3
S1N1STR
rwhxk3's Avatar
I haven’t found them new for under $1600. But I may be looking in the wrong places.
Old 01-12-2018, 03:55 PM   #9
JosefJamesRS
Drives: 2011 LT1 RS
Thanks everyone for the input on this, you've all been very helpful. Now considering the price, would removal of the ground effects cause any VISIBLE damage? I'm fine with if its under the car or hidden very well. Thank you.
Old 01-12-2018, 03:59 PM   #10
bayarea408
bayarea408's Avatar
Drives: T
the SS front GFX has tabs drilled in to hold the lip level if installed correctly by a dealer. The V6 might have these tabs as well.
bayarea408 is offline   Reply With Quote
Old 01-12-2018, 04:19 PM   #11
JosefJamesRS
Drives: 2011 LT1 RS
Do you know if you can see the drilled holes by any chance?
Old 01-12-2018, 04:28 PM   #12
bayarea408
bayarea408's Avatar
Drives: T
yes, it was the reason i did not follow through with the GFX kit installed. i wasnt 100% on the front lip and did not like the idea of drilling like 8 or 10 tabs to hold the lip.
Old 01-12-2018, 04:35 PM   #13
pyroguy
pyroguy's Avatar
Drives: ABM #832
In addition to the holes in the front bummer cover you will need new rocker pieces as the ground effects pieces replace the non-ground effects rockers.
Old 01-12-2018, 05:24 PM   #14
JosefJamesRS
Drives: 2011 LT1 RS
Where can I find one? (OEM)
camaro parts, ground effect, help me i'm a noob, selling original parts
