Old 01-09-2018, 11:25 PM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Best SS Brake pads for daily driver
Hey guys I'm going to change my pads and possibly turn my rotors before the spring hits and I'm looking for the best overall budget friendly pads.
I DO NOT under any circumstances road race or auto x my car so I'm not interested in anything that's going along that route. It gets driven about 3x per week in the summer and I take it to the drag strip occasionally throughout the season.
Also this is not a 1le car, just A regular SS. If possible Please include part #'s as well.
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Old 01-10-2018, 05:35 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
Word on the street is the plain, ol' OEM pads are all you need for your purposes.
KillboyPowerhead is offline   Reply With Quote
Old 01-10-2018, 06:44 AM   #3
vinman
The BBOMG fill-in husband
vinman's Avatar
+1 oems are actually great pads
UPSTATE C5 MEMBER
calipers, hawk ebc brakes rdp
