| View our official forum sponsors list. |
Thread Tools |
Nick williams 102mm throttle body on sale and in stock at juiced!!!
Nick Williams Performance drive-by-wire throttle bodies are CNC precision-machined from billet aluminum to meet the demands for increased airflow on the drive-by-wire LSX performance engines. The 102mm throttle bodies require an aftermarket intake to fit the larger diameter throttle blade. They use a 6-pin late model connector that works with late model wiring harnesses. Tuning is required for installation; and the Nick Williams Performance drive-by-wire throttle bodies come complete with stepper motor and electronics installed—no need to disassemble your factory throttle body.
![]() 102MM DRIVE-BY-WIRE LS THROTTLE BODY 102MM DRIVE-BY-WIRE BOOSTED LS THROTTLE BODY (FOR CARS MAKING SERIOUS BOOST) |
Does CAI intake fit this?
If you plan on making over 15psi we highly recommend the 102MM for boosted applications.
Yes, you just need to stretch the boot a little bit but most intake kits should work fine |
These systems are a must for roots style blowers. The more air you can get to your blower means the more air you can boost. Pm or call for ported blower package deals
#6 |
A roots style blower can only boost as much air that you can push into. With a opening approximately 15% larger you can make a greater amount of power.
#7 |
Great power gains
#8 |
#9 |
Take full advantage of that blower.
#10 |
Order online or give us a call for pick up or installation and tuning
#11 |
These add big power on boosted cars. In stock and priced right
Need a tune? PM or call for an appointment |
#12 |
#13 |
NW 102MM in stock
#14 |
In stock
| Tags |
| 102mm throttle body, nick williams |
