Old 01-13-2018, 01:18 PM   #1
kyrebel
Drives: 2011 camaro ss
camaro sways back and forth
I have a procharged ss with ZL1 cradle.i was doing the 1/2 mile airstrip drags and sometimes it would start swaying back and forth and get a little scary.i have 315 Michelin pilot super sports on rear and 285 on front and was running about 35 psi.I don't feel like it was losing traction.any ideas
kyrebel is offline   Reply With Quote
Old 01-13-2018, 02:54 PM   #2
JOHNSONROD
JOHNSONROD's Avatar
Drives: 62 Chevy & 2021 1SS/1LE manual
wore out toe rods will do that. what rear sway bar are you running?
JOHNSONROD is offline   Reply With Quote
Old 01-13-2018, 03:13 PM   #3
kyrebel
I have new bmr toe rods.i am using stock ZL1 sway bar in rear and stock SS in front
Old 01-13-2018, 04:39 PM   #4
JusticePete
Drives: Camaro Justice
What are your alignment specs. Posting the sheet would be a big help.
Old 01-13-2018, 04:47 PM   #5
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
I know the feeling but have no answer
Old 01-13-2018, 04:48 PM   #6
kyrebel
I had alignment done by a friend at tire discounters.i would say they put to factory specs.car just has 11k miles on it
Old 01-13-2018, 05:28 PM   #7
JusticePete
We need to know what the rear camber and toe settings are. Ask your friend to put the car back on the rack and double check everything.
Old 01-13-2018, 05:29 PM   #8
JusticePete
Mike, please post your specs too.
Old 01-13-2018, 05:59 PM   #9
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Before I did my alignment according to Pete's specs, my car was swaying back and forth under hard acceleration.
More to come.
Black_SS10 is offline   Reply With Quote
Old 01-15-2018, 10:23 AM   #10
kyrebel
JusticePete,wont be able to get it to alignment shop for a few months.snowed in.he told me they used factory specs.is there a setup that it should be besides factory that works
Old 01-15-2018, 10:51 AM   #11
JusticePete
I am guessing the rear tor is out of spec. It may have been set incorrectly or slipped.
Old 02-01-2018, 08:17 PM   #12
JS1
Drives: Black 2013 2SS RS 1LE
Justice Pete, remember mine doing that a few months ago and it was a ferrel that was too big for the bolt in one of the new BMR parts? Nothing wrong with the part or installation just the wrong size sleeve for the bolt. Hardly noticeable just looking at it but very noticeable under hard acceleration. You tracked it down easily and I swapped it out later.
JS1 is offline   Reply With Quote
Old 02-01-2018, 09:59 PM   #13
JusticePete
Yes I do and how are you? How is your beast?
Old 02-02-2018, 08:50 PM   #14
JS1
Doing great. Hope you are. I'm ready for the JPSS rear sway bar. Will you be at vir the first week of March with Chin? You want to try to do it then? What else should we do? Caster plates, z28 control arm bushings, radius arm bushings? Can we do that without missing track time?
