Old 01-14-2018, 03:06 PM   #1
BigMacLA
BigMacLA's Avatar
Drives: 2012 2ss
Trunk release please help!
I can’t open my trunk. When I push the bottom on he door I hear a clicking noise. I can access by opening the seat.
If I pull the emergency release in the trunk will it remain open? Any suggestions? It’s fridgid cold so not sure if that is effecting it.
Please help!!
BigMacLA is offline   Reply With Quote
Old 01-14-2018, 03:17 PM   #2
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
It will not be stuck in the open position. The emergency release just leleases the lock. Once you close the lid it will relock. As for your trunk button issue, ck the fuse maybe its blown or maybe it's the cold as your thinking.
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
Old 01-14-2018, 03:24 PM   #3
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I may not be reading this right but if you pop the e-release you will still have to use some effort to open the deck lid. Our trunks do not fully open on their own.
Moto-Mojo is offline   Reply With Quote
Old 01-14-2018, 04:04 PM   #4
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
I would start with getting that battery checked unless it has been replaced from original...just sayin...
Old 01-14-2018, 04:19 PM   #5
BigMacLA
BigMacLA's Avatar
Drives: 2012 2ss
Ok the release worked and I’m able to open the trunk. However, the remote and door bottom still don’t.
Old 01-14-2018, 04:26 PM   #6
Michaels_45
Michaels_45's Avatar
Drives: 2012 45th Anniversary Camaro 2LT RS
I've been having problems with my trunk. I hear the clicking noise when I press the buttons. If I push down on the trunk as I hit the button, it works 100% of the time. Just a quick fix to keep in mind
Michaels_45 is offline   Reply With Quote
Old 01-14-2018, 05:55 PM   #7
Low Saturn
Low Saturn's Avatar
Drives: 2011 Camaro 2SS/RS
There is a TSB for this and an updated designed latch. I had mine replaced a couple years ago on my 2011 SS. Did the exact same thing as you're describing.
The click you're hearing is the relay. Which means the bottom on the door, the remote button and the relay are working. So it's a latch or wiring problem.
Low Saturn is offline   Reply With Quote
Old 01-14-2018, 07:04 PM   #8
BigMacLA
BigMacLA's Avatar
Drives: 2012 2ss
You are right on track. I checked the fuse and it’s good, the relay is making the clicking noise.
Was this TSB a recall? Was it expensive? I’m not too technical, but anything I can do to fix it?
Old 01-14-2018, 07:46 PM   #9
Low Saturn
Low Saturn's Avatar
It didn't cost me anything.
Old 01-14-2018, 07:51 PM   #10
InFiD3ViL
InFiD3ViL's Avatar
Do the TSB's only cover warrantied vehicles/original owners?
If not, I need to check my 2010 SS L99 for any. I am not an original owner so I wouldn't have gotten any notification.
Old 01-14-2018, 09:12 PM   #11
Low Saturn
Low Saturn's Avatar
I'm pretty sure I have the TSB on my computer at home. I'm at my cabin for the weekend, but I'll look for it when I get back.
