V6 banger
Drives: 2016 Lexus CT200H Join Date: Apr 2017
2013 LS M6 rear diff fluid
I have 76k miles on my 13 V6 6-speed manual Camaro. I believe the rear diff fluid is recommended by GM to be replaced at 60K. Has anyone done it before and what fluid was used? I don't mind paying for the high price of GM fluid, just not sure if there is another aftermarket that is recommended for my car. After some tuning, more bolt on parts I'd assume the HP would be in the 380-390 range (flywheel not to the wheels). Any help would be great, thanks!
2016 CT200h (daily)
2017-2020 V6 (currently looking to buy) 2013 LS 6-speed (SOLD) Elite E2 catch can, CAI intake, 2.5" SLP Loudmouth II mufflers with no resonators with an X pipe, Kenny Racing ported TB, Jacfab spacer and ported manifold and Accelerated Racing E85 octane dyno tune = 300WHP ![]() Special Thanks to... Jason@JacFab, ChibBlackSheep, Kenny Racing & Accelerated Racing (use to be in) Rancho Cucamonga CA. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
You should have done this fluid about 70,000 miles ago. That stock stuff was DISGUSTING after a few thousand miles.
I change mine every other spring, it's super easy to do. You'll need 1qt of 75w-90 gear oil and a bottle of GM posi fluid. (https://www.amazon.com/Genuine-88900.../dp/B0028CMPIS) You should do the transmission fluid at the same time. It uses the same 75w-90 fluid that you decide to use in the diff. You'll need about 2qts for the trans. I went with Mobil 1. You can choose whatever full-synthetic 75w-90 that you want. In the end, your check-list would be: 3 qts of 75w-90 gear oil. (4 if you want to be on the safe side and might spill some) 4oz of GM additive 1 pump to move the oil.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
![]() Drives: 2014 2LT RS Join Date: Jan 2016
I used Mobil 1 gear oil and just did mine today. Ramps on the rear and jackstands for the front. Both axle and tranny were easy but a learning experience. 3 quarts filled both perfect with the friction modifier for the axle.
I used Royal Purple. Had the Diff and Tranny done at the same time.
![]() ![]() ![]() ![]() ![]() Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
I prefer Redline GL5 75W-90 for my trans and differential. Works like a charm.
#6 |
![]() Drives: 2018 1LE Join Date: Nov 2017
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Lucas non-synthetic.
![]() And it's never to late to change it.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
#8 | |
V6 banger
2016 CT200h (daily)
#9 | ||
V6 banger
they make non-synthetic?
2016 CT200h (daily)
#10 | |
As long as your rear-end isn't howling, you shouldn't need to do a "flush" to it. Just make sure you clean the magnet well, and do a few figure-8s after you put the diff fluid in to get it moving all around. And make sure you wear gloves and hold your breath... this stuff stinks!
#11 |
I've been putting this off for a year. Thinking it would be hard and messy.
Just did it yesterday on my SS M6, trans and diff. Super easy. Hardest part is getting the car up on jackstands, then operating the little pump I bought to pump in the new juice to my transmission. It was a little messy, but that was my bad for missing the mark to catch the trans fluid ![]() I had to use ATF for the SS M6 trans fluid, I used amsoil for that. I used Mobile 1 75-90 LS for the diff, with a little GM ls additive. Wow, shifting is much improved, very much needed. I'm still not thrilled with the diff performance, but at least I know the fluid is fresh. I had the usual accumulation of metal on the magnetic plugs. I've got an eaton truetrack waiting to go in when I find a good shop to do it. |
#12 |
#13 | |
V6 banger
2016 CT200h (daily)
#14 | |
![]() Drives: 2015 Camaro 1SS 6M Join Date: Dec 2017
I've had two friends spin rod bearings with royal purple. I'll never waste money on it. Redline all day for me.
