Old 01-23-2018, 04:54 PM   #1
MIDNIGHTANGEL
Back4Revenge
MIDNIGHTANGEL's Avatar
Drives: BLACK CAMARO
Send a message via AIM to MIDNIGHTANGEL Send a message via Yahoo to MIDNIGHTANGEL
Supercharger and Throttle Controllers...
So fellas, what's you're input? *Stealth 3.0? *VTC? *Don't do it?
I chose my 6 with Pride..
MIDNIGHTANGEL is offline   Reply With Quote
Old 01-23-2018, 07:36 PM   #2
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
None. If you need a throttle controller to make your car feel fast then you bought the wrong car.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 01-23-2018, 08:56 PM   #3
MIDNIGHTANGEL
Back4Revenge
The throttle control Gives that insta-oomph then the headers handle the mid range and the supercharger seals the deal - Am I Right?
Old 01-23-2018, 09:55 PM   #4
bingster223
bingster223's Avatar
Drives: 2015 1LT/RS hot red/black
I took my VTC off my car. It started putting my car into reduced power service stabili track. Hasn't done it once since its removal. Besides gonna get it tuned soon so i dont miss it either.
Sent from my SM-G955U using Tapatalk
bingster223 is offline   Reply With Quote
Old 01-24-2018, 12:44 PM   #5
MIDNIGHTANGEL
Back4Revenge
That actually happened to me before too.. Then comes the question .. will the Stealth 3.0 do that too? So many options..
Old 01-24-2018, 06:23 PM   #6
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I had the manual trans on my IPF S/C V6 and the VTC would bring in too much gas before the clutch was fully engaged resulting in premature wear.
Might be fun having unexpected wheel spin on an automatic trans but not worth
the cost otherwise IMHO. Took mine off.
Old 01-24-2018, 06:37 PM   #7
MagnumForceGB
Headers should give power to all RPM range if they are the right ones. And "insta-oomph" it bad when you are trying to go fast and the tires are spinning. I've had my car sideways at 70 mph heading for a ditch, I make sure it never does that again.
Old 01-25-2018, 05:58 PM   #8
MIDNIGHTANGEL
Back4Revenge
Definitely understandable-
Old 01-27-2018, 11:04 PM   #9
djrasras
djrasras's Avatar
Drives: 2010 2LT Bumblebee
When I had the IPF I did not like the Throttle controller after I got a proper tune. It was a neat thing to use here and there before I got the tune, but overall I would say no its not worth the hassle and possibility of a Stabilitrak warning
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
djrasras is offline   Reply With Quote
Old 02-02-2018, 07:57 AM   #10
Slowhawk
Drives: 1999 Trans Am
If you moved your foot it will do the same thing as the controller. The controller just makes the TB open more at less throttle.
Slowhawk is offline   Reply With Quote
Old 02-07-2018, 09:37 PM   #11
djrasras
djrasras's Avatar
I could be wrong but when I did tests of flooring it with the controller at a 10, and then flooring it when I took it off (for good), it definitely felt like the TB was opening up noticeably slower.
Old 04-11-2018, 08:14 AM   #12
Cam_with_Overkill_motors
Drives: 2014 Canaro 2Lt RS Convertible
Stealth 3.0 has never given me a problem. Now the others ones, a complete nightmare!
Cam_with_Overkill_motors is offline   Reply With Quote
Old 04-11-2018, 11:33 AM   #13
bleavens1962
Drives: 2014 1LS Camaro
Throttle Controller for a Super Charged car ? How much quicker do you think you will get to that next red-light ? I am S/C btw and you couldn't pay me to put a TC on my car
bleavens1962 is offline   Reply With Quote
Old 04-18-2018, 01:26 PM   #14
MIDNIGHTANGEL
Back4Revenge
I don't know man its just a feel that little drag in the beginning.. So Stealth 3.0 is what I'd want to go.. Quicker response on that bunny hop then dropped back off for when the business is real.
