Old 01-25-2018, 11:07 PM   #1
hou30guy
Drives: 2011 convertible 2ss/rs
Guesstimations on my setup hp
what should i see with the 10.1 compression on a 2.7 sc pulley, 10 rib setup, left coast 32 new front hybrid bracket and ati 6% od, btr pds blower stage 3 cam,lt headers,fore dual 450s pump, 1400cc injectors on the 408 stroker on e85 and pump 93. Its currently on 93 pump only at 648whp on 3.2 sc pulley but was with slippage. New setup will have no slip due to new bracket design 75% belt wrap vs the original 50%
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 01-26-2018, 09:48 AM   #2
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
I would be concerned about belt slippage with that small of a pulley. My opinion is you need more blower, but hey, chew up the meat and spit out the bones.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 01-26-2018, 11:08 AM   #3
hou30guy
I did the left coast 32 hybrid front bracket for no belt slip. At 1st it was only 50% belt warp now its 75%. It had belt slep especially with original bracket at wot. I just made all the proper changes last night. And im gonna use the 3.1 pulley instead. See the new design belt wrap verse old belt wrap. New style has the thin belt on the 10 rib. Yes the belt is thin cause griptec sent me a belt length checker so it was only for checking length of the new belt to order lol. But my setup is 10 rib
Old 01-26-2018, 12:49 PM   #4
BiggFoot
BiggFoot's Avatar
Ahh, you should be good then.
I was near 800 hp with my Maggie maxed out at 12-13 psi on E85 but I had some aftermarket heads.
Since you have the 408 stroker instead of my 376, I am thinking you should be about the same ~ 800 hp on E85 if your blower is at least equivalent to a Maggie 2.3
Blower Cam
RPM Level VII
TR6060
Old 01-26-2018, 12:56 PM   #5
BiggFoot
BiggFoot's Avatar
Ooops, your auto?
Blower Cam
RPM Level VII
TR6060
Old 01-26-2018, 01:16 PM   #6
hou30guy
Lol yuuuup love it too
Old 01-26-2018, 01:17 PM   #7
hou30guy
Yeah its the tvs2300 and my ls3 heads ported, i do have a 102mm tb just waiting on the boosted cap to come to swap it
Old 01-26-2018, 01:19 PM   #8
hou30guy
Maggies are good for more than 800, left coast has a maggie on a 390 ci on YouTube doing 1019whp
Old 01-26-2018, 01:20 PM   #9
hou30guy
https://youtu.be/jsisVu8bbso
Old 01-26-2018, 03:37 PM   #10
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
thats crankshaft hp. they're also using a solid roller cam setup. that's around 800whp, hate to break it to you. if you want anything more than 800whp you will need a bigger blower.
ttshovel is offline   Reply With Quote
Old 01-26-2018, 04:30 PM   #11
hou30guy
I forgot it was crank but thats still roughly 850whp, thats great for them blowers. If i could get 750 to 775whp ill be happy with mines
Old 01-26-2018, 07:30 PM   #12
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
775 is great! But then it's not 900. LOL!!
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 01-26-2018, 07:52 PM   #13
hou30guy
True lol 700+ plus is ok for Tx2k18, 1k whp is ideal lol but i dont drag or track just a street guy
Old 01-26-2018, 11:19 PM   #14
Taylortoons
O2b 1000 hp in Tx2k18
