Old 01-28-2018, 04:44 PM   #1
inglopez19
Drives: Camaro 2010 SS
2010 Camaro SS Turbo or Supercharger ?
Hello guys !
I got a 2010 Camaro SS and made some performance stuff to my car.
BTR LS3 N/A STAGE II 3 BOLT CAM
K&N Intake
Long Headers
Exhaust 3''
Car tunned
So im in the process now to choose between a turbo kit or an supercharged
to my car.
What you guys think is my best option here ?
inglopez19 is offline   Reply With Quote
Old 01-28-2018, 04:58 PM   #2
Silver14
Drives: 2014 SIM 2SS
Depends what you do with the car. You'll get different answers if it's a daily driver, primarily drag car, auto or manual, etc.
Silver14 is offline   Reply With Quote
Old 01-28-2018, 05:18 PM   #3
inglopez19
Hey !
Its not my daily car, mine is manual.
Old 01-28-2018, 09:49 PM   #4
TWOFORTYZ
Drives: 2015 Camaro 1SS 6M
What are the specs on the cam? Lift, duration, LSA, and overlap?
TWOFORTYZ is offline   Reply With Quote
Old 01-29-2018, 07:41 AM   #5
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
You may not be getting a lot of response because your question is just too open ended. If you don't already understand some of the basic advantages/disadvantages of turbo VS supercharger then I recommend you read the sticky in this section about them. It is good reading and someone went to a lot of trouble to put it together.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 01-29-2018, 09:30 AM   #6
Jacoup
Ultron
Jacoup's Avatar
Drives: 2014 UPP TT
Turbo
2014 UPP Twin turbo, 376 LSX B8, Custom stingray lip kit, Z28 spoiler wicker bill, BC coils, LSR sways, Zl1 Strut brace
IG: abosulte_jacoup
Jacoup is offline   Reply With Quote
Old 01-29-2018, 09:38 AM   #7
inglopez19
Good morning
Cam specs !
LS3 Stage II 3 Bolt Cam 225/238 .612"/.585" 113+3
Old 01-29-2018, 09:39 AM   #8
inglopez19
I do understand some of the basics, want to read some of the past experiences from somer users here in the forum. But yes, i will keep reading some old post also.
Old 01-29-2018, 09:58 AM   #9
hammdo
'It's an experiment'
hammdo's Avatar
Member's build section (Member Car Journal) -- you'll see what folks started with and what they have currently -- and why they chose what they did. Lots of answers there.
It boils down to what you want to do with the car as opinions are going to be 'personal preference'. Advantages to both...
-Don
747 RWHP 794 RWTQ
Old 01-29-2018, 11:58 AM   #10
AGP Turbo
Drives: All things Turbocharged
The manual cars are over built quite a bit from the factory. We have a number of customers who've done 800+whp on E85, stock LS3 cars just adding our turbo kit and fuel system.
AGP Turbo is offline   Reply With Quote
Old 01-29-2018, 12:04 PM   #11
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Just to set the record straight - turbo(s) or supercharger will really float your boat. Can't go wrong with either, and either camp will justify their awesome results. As everyone else has stated, it depends on how you want your car to drive with what you're doing with it. Specifics will help.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 01-29-2018, 02:20 PM   #12
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
Turbo will likely require something other than your long tube headers and/or custom exhaust modifications to retain them.
Both will likely require the front fascia of the car to come off in order to install the heatexchanger/intercooler. (a couple of turbo/SC kits [like the ECS kit] do not require this)
both will require a fuel system upgrade. anytime you introduce more air in that volume into the motor, you will need to add more fuel. lots of times the turbo/supercharger kit come with them
supercharger will give you instant power off the line
turbo will likely require you to spool up and maybe invest in a 2-step
both make ridiculous power and i wish i had either.
These are just basics. You have to decide what you want the car to do and how you will be using it in order to decide whats best for you. Hope this helps
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 01-29-2018, 02:39 PM   #13
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
What kind of budget do you have? And also if there is a budget will you be doing the install or have a shop do the install,turbos normally cost more for install
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 01-29-2018, 03:05 PM   #14
inglopez19
Got it thanks for the advice !
