Old 01-29-2018, 06:15 PM   #1
silver.ice18
silver.ice18's Avatar
Drives: 2014 2LS
muffler delete
I'm planning to do a muffler delete on my 2014 v6 camaro and so I went around today asking for prices on it and most of them said $150. Is it worth it? Drone wouldn't matter to me and neither would how loud it is. I found a couple of videos on youtube and these 2 stood out to me
https://youtu.be/UOH4WWlUPog
https://youtu.be/hggmK-KaTDQ
silver.ice18 is offline   Reply With Quote
Old 01-29-2018, 10:25 PM   #2
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
If you want to do that, you want to add the Magnaflow #11386 muffler in place of your current H pipe. If you don't, your car will scream but it'll be high pitched and raspy as hell and just not pleasant.
$150 sounds like a bit much if they're just cutting the mufflers and welding in a section of pipe, but I could be wrong. Unless you're going to cut from the H pipe back and weld in all 2.5" piping, then you'd be ripping them off. Lol. Those videos are pretty much what it would sound like. Try looking up a muffler delete with the Magnaflow Resonated X (or Magnaflow 11386, same thing) and get back to us.
DSX_Camaro is offline   Reply With Quote
Old 01-30-2018, 11:27 AM   #3
Cenafan85
Cenafan85's Avatar
Drives: 2014 Camaro 2LS
muffler delete on a V6 sounds bad. I know a lot of guys will say it sounds good, but it doesn't. Get a nice exhaust and pair it with res X pipe and some high flow cats.
2014 Camaro BLK 2LS, MRT 2 exhaust,CAI,Anzo projector headlights,Morimoto HID,Aftermarket fog lights,RS tail lights, Strut tower brace.
Cenafan85 is offline   Reply With Quote
Old 01-30-2018, 02:52 PM   #4
BTORRES2012
BTORRES2012's Avatar
Drives: 2013 Inferno Orange Camaro 2LT/RS
I wouldn't recommend a muffler delete. I did it and immediately regretted it. It was way too raspy and high pitched. It sounded horrible.
BTORRES2012 is offline   Reply With Quote
Old 01-31-2018, 09:17 PM   #5
silver.ice18
Drives: 2014 2LS
So I went with the muffler delete just to try it out. Cost me $137 (cheapest I could find with a reputable shop). Overall it makes it alot louder and it does sounds good, but there may be just too much rasp. Should I add a magnaflow x-pipe? Would that help with making it a bit quieter?
Old 01-31-2018, 09:54 PM   #6
DSX_Camaro
DSX_Camaro's Avatar
It would make it a little quieter but it would kill most of the rasp and give it a deeper tone. Highly recommend adding it. Magnaflow 11386
