![]() Drives: 2010 Camaro 2LT RS Join Date: Jan 2018
No Reverse lights
I have a 2010 2LT with the manual transmission. When I put it into reverse, I no longer get the beep or the big 'R' displayed in the DIC, and the reverse lights don't come on.
The reverse lights will still illuminate when I unlock the car with the key fob. I had figured it was a faulty reverse switch, so I ordered a new one. Once replaced, the new switch did not make a difference, and checking the old switch it still had continuity when I checked it with a volt meter. Anyone have any ideas where to check next? Any idea where the reverse switch circuit gets wired to, so I can do a little more investigation with the voltmeter? |
![]() Drives: 2010 Camaro SS LS3 Join Date: Oct 2016
This seems like a really rare issue, since the lights go on when you unlock the car.. I'm not sure if there is a fuse for the reverse switch, but if there is maybe it's blown?
Checked most of the fuses inside the dash. Looked all good. I'll have to try following the wires from the switch to wherever they terminate.
#4 | |
https://www.youtube.com/watch?time_c...&v=-ogXZ7D16xw |
Finally figured it out. One of the two wires had pulled out of the connector for the reverse switch in the transmission.
#6 |
