Old 01-30-2018, 11:14 AM   #1
ATX_SS
Drives: 2013 Camaro SS L99 Vert
"Cheaper" Intakes Question
I am seeing all these no name brand intakes on Ebay (links below) but wanted to know your options on these things. I mean they have the same concept - elbow, housing/shield, cone. So what, if any, would be the performance difference from a $400 Volant, Airaid, K & N, Cold Air Inductions, etc. from one of these? These seem legit in terms of overall design. I could see the major difference being the quality of the filter itself. Truth is a lot of these smaller parts are fabricated and made overseas and some are the same parts or made in the same factories! I'm sure there is some variance in overall quality such as cheaper plastic. I do understand you get what you pay for but the range ($150-$500) is a little thought provoking. Thoughts?
https://www.ebay.com/itm/2010-2015-C...xYHQ90&vxp=mtr
https://www.ebay.com/itm/For-2010-20...paFdOE&vxp=mtr
https://www.ebay.com/itm/4-BLACK-Hea...FWe0n9&vxp=mtr
ATX_SS is offline   Reply With Quote
Old 01-30-2018, 11:27 AM   #2
Mr. Hyde
Mr. Hyde's Avatar
Drives: 2015 Camaro 2SS
Having just installed the C.A.I. setup, it was easy and the parts fit well. The heat shield dropped right in and lined up with the sheet metal in the engine bay. Cheaper kits may not fit as well and of course use cheaper quality parts. Lesson learned, I used a cheap eBay kit on my truck and it was ok, but didn't fit near as well as my buddy's Volant. The cheaper kits will work, get air to the engine etc but I suppose it depends on the individual's level of OCD. I wanted a clean look and tight, straight fit...which I got with the C.A.I. unit. I promise I don't work for them lol...just sharing my worthless $.02
Mr. Hyde is offline   Reply With Quote
Old 01-30-2018, 11:46 AM   #3
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
IMO, if cost is an issue, I would look into a lightly used, (but known brand) intake over a new but cheap kit
I bought a Rotofab CAI off a member here for $200 shipped. It is 1 small scratch away from looking brand new. And while cheap, I got a well made one that fits perfect, and looks pretty much new after cleaning.
If I had to do it again, I would do the same thing.. I have bought a cheap ebay kit for a previous vehicle. While it "worked", sure..there is a very noticeable difference in quality.
You have a nice ride man, I'd spend the little bit more for nice parts to compliment it. Just my 2 cents
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 01-30-2018, 11:46 AM   #4
ATX_SS
Thanks for the feedback CAI is the direction I am leaning more towards as well if going with a name brand. And good point with the fitment being just right.
Old 01-30-2018, 11:47 AM   #5
ATX_SS
I bought a Rotofab CAI off a member here for $200 shipped. It is 1 smalls scratch away from looking brand new. And while cheap, I got a well made one that fits perfect, and looks pretty much new after cleaning.
Thanks man what you said all makes sense.
Old 01-30-2018, 02:42 PM   #6
supashane
supashane's Avatar
Drives: 2011 Camaro SS L99
There are usually a few cold air intakes for sale in the member marketplace here in the forum.
http://www.camaro5.com/forums/forumdisplay.php?f=30
you can check there first for a good deal usually. I got a great deal on mine recently. If you do get one used keep in mind that you may have to get a PCV hose for the crankcase vent if they don't have one to ship with the intake. You should be able to get one cut to whatever length you need at the local auto parts store.
*SOLD* 1997 Camaro L36, Arctic white, manual, stock af
supashane is offline   Reply With Quote
Old 01-30-2018, 05:47 PM   #7
Avenging Orange
Avenging Orange's Avatar
It's the same on lots of aftermarket parts......concept is the same and most will function as designed. You just need to be cautious of prices that are too good to be true. But the same is true on the high dollar stuff....you end up paying for the name. I usually pick middle of the line.....had good luck.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 01-30-2018, 06:45 PM   #8
Bo White
Bo White's Avatar
I know a guy running a Spectre intake, ported TB, hot cam, TSP headers and a tune and loves the hell out of it. Been driving it that way for atleast 2 years. Hes happy.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 01-30-2018, 07:06 PM   #9
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
I'm gonna refrain from mentioning brands etc.. and give you good logic behind an aftermarket air intake! Typically any aftermarket design over stock intake design is an improvement. The better ones would be a design that allows cooler exterior air in (outside of engine bay) instead of warm air from the engine bay.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 01-30-2018, 07:17 PM   #10
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Yep.....i ran into a guy last year at a car meet with Spectre cai big cam and longtubes. I had to ask if he liked the Spectre. His car had been modded that way for a few years and he loved it. So who knows.
rontammy0 is offline   Reply With Quote
Old 01-31-2018, 05:27 AM   #11
sdynak
Drives: 2014 ZL1
Just watch the ones with the rubber/silicone 90 at the TB.. have seen videos of that area collapsing.. prob not much difference on the hard piped ones other that brand/fitment/bragging rights.
2014 ZL1 Black All OEM, Manual
SOLD: 2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
Old 01-31-2018, 09:24 AM   #12
go_go_gadget88
Not a car, but I had a Spectre on my last truck. No fitment issues and it worked fine. Probably the best "budget" one out there for quite a few vehicles. I just don't really care for the shiny metal pipe under the hood on camaro so it wasn't an option to me for this ride. For a couple dollars more, I'm fine with what I bought. But performance between them all is probably minimal.
I have had one of those super cheap ebay ones before, and had nothing but issues with the thing. I will stay stock before I ever waste my money on another one of those.
Old 01-31-2018, 10:09 AM   #13
Bo White
Bo White's Avatar
That is the first design Spectre. I hadnt seen one of them in probably over 5 years.
Totalled:
Old 01-31-2018, 10:18 AM   #14
sdynak
Drives: 2014 ZL1
Yeah.. I think there was also some questioning of how the issue itself was introduced like covering the end..
Anyway.. seeing the design in the 2nd link is what reminded me of seeing that.. Can't tell for sure if that is a hard or soft 90.
