![]() Drives: 2014 LS Join Date: Apr 2014
Water getting inside the engine through hood scoop?
Hello,
I am planning on installing a hood scoop on my camaro. The 2014-2015 that comes with the SS camaro. ![]() You'd usually need to add a water drip tray underneath in order to redirect the water. My question is, would the water going inside the hood cause any damage to the engine or any other parts? Electronics? Thanks |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Love the one you're with Join Date: Sep 2009
The OEM one has a plastic diverter that directs water out in front of the hood latch.
![]() Drives: 2013 Camaro SS Join Date: Oct 2016
It depends on what conditions you drive your car. Is it a year round regardless of weather car or is the only time it gets wet is at a car wash? If it's the first I would add the tray if it's the second you could probably skip it. Skipping it would allow more heat out.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
i could drive year round without the tray, but i install it during the winter to help keep heat in the engine bay. not much water gets in with the tray removed
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
![]() ![]() ![]() Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
The diverter actually diverts the water to a drip tray that is on top of the radiator, then the water runs down to the left and right and out the bottom of the car.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
